Antigram Question
FreddyDapice
Vital BMX member FreddyDapice
93951 FreddyDapice http://p.vitalbmx.com/photos/users/93951/avatar/c50_IMG_0884.jpg?1366813634 http://www.vitalbmx.com/community/FreddyDapice,93951/all 05/12/12 6 http://www.vitalbmx.com/community/FreddyDapice,93951/setup 251 5262 31 9
11/21/2013 5:03 AM
I've noticed that when my rear wheel is tightened down my driver still has some play? Shouldn't it be pretty tight? How do I fix?
Phone - 704 - 797 - 6844
andyferly
Vital BMX member andyferly
73863 andyferly http://p.vitalbmx.com/photos/users/73863/avatar/c50_s780_Street_bmx_faces.jpg?1341945114 http://www.vitalbmx.com/community/andyferly,73863/all 01/04/11 6 1 http://www.vitalbmx.com/community/andyferly,73863/setup 89 5918 8 5
11/21/2013 5:37 AM
I have the same thing with my Shadow Raptor, every once in a while I just tighten the locknut by hand when I see it's loose.
Shouldn't be a problem.
FreddyDapice
11/21/2013 5:39 AM
Everything on the antigram is press fit.
dave lawrence
Vital BMX member dave lawrence
20481 dave lawrence http://p.vitalbmx.com/photos/users/20481/avatar/c50_Skate_or_Leave_1466620531.jpg?1466620278 http://www.vitalbmx.com/community/dave-lawrence,20481/all 05/23/08 100 39 1 http://www.vitalbmx.com/community/dave-lawrence,20481/setup 243 17665 529 2 32
11/21/2013 5:54 AM
Add a spacer?
I am sick and tired of the "cliques" that this sport has recently developed. We should embrace the fact that we all ride a little kids bike, and not worry about the small details. When you take riding in its most basic form, we are all the same.
HardBMX_Tim
Vital BMX member HardBMX_Tim
106966 HardBMX_Tim http://p.vitalbmx.com/photos/users/106966/avatar/c50_IMG_41431155304659_1415905782.jpg?1415905117 http://www.vitalbmx.com/community/HardBMX-Tim,106966/all 07/15/13 3 299 4835 7
11/21/2013 6:24 AM
dave lawrence wrote:
Add a spacer?
This. The pull of your axle bolts on the center axle could cause the center axle to stretch out maybe just 0.2mm past the press hardware. Another possibility is the press hardware could have been "crushed" down maybe just 0.2mm down the axle. Try adding a spacer that will fit over the center axle on the side that's loose and use a rubber mallet to tap the press hardware on a bit tighter. This will ensure that when tightened, the press hardware is being fully pressed into the hub. If you're axle is touching the inner drop out instead of the hardware, there's nothing pushing the hardware into the hub.
Gump
Vital BMX member Gump
93698 Gump http://p.vitalbmx.com/photos/users/93698/avatar/c50_fb_picture_1177779123.jpg?1336281831 http://www.vitalbmx.com/community/Gump,93698/all 05/05/12 3 1262
11/21/2013 6:35 AM
I would just contact odyssey/gsport for advice. I think my ratchet has a small amount of play
Chuck8273
Vital BMX member Chuck8273
86726 Chuck8273 http://p.vitalbmx.com/photos/users/86726/avatar/c50_image_1378092142.jpg?1378091187 http://www.vitalbmx.com/community/Chuck8273,86726/all 11/03/11 14 15 http://www.vitalbmx.com/community/Chuck8273,86726/setup 67 5742 11 2 10
11/21/2013 7:25 AM
Of the two things Tim mentioned, I would suspect the spacer being slightly flattened, or what you're seeing just could be within working tolerance. Email them, complete with pics of the driver to both the extreme left and extreme right. You will probably get better pics without the chain installed. If your chain rubs on either the hubshell or the dropout, then even if they say its fine, I would go to a hardware store or auto parts store and see if they have any stainless shim stock available.
Soulrebelrastaman
Vital BMX member Soulrebelrastaman
102984 Soulrebelrastaman http://p.vitalbmx.com/photos/users/102984/avatar/c50_image_1423173800.jpg?1423173468 http://www.vitalbmx.com/community/Soulrebelrastaman,102984/all 02/09/13 95 2237 20
11/21/2013 7:29 AM
I had the same concern with my bsd backstreet, I emailed bsd and they said its fine, its just because they are press fit hubs and as long as everything is pushed together there's nothing to worry about, and that a slight bit of movement is to be expected.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
andyferly
11/21/2013 8:11 AM
I know that, what I meant is it shouldn't harm the driver having a bit of lateral play as long as it's not too much.
