okay i just got a new frame
and i've been riding with brakes for a whil
and i've decided it's time for them to go
so besides the obvious solution of hacking through them with a sawzall
anyone have any clever ideas on how to remove the brake stops and cable guides? 24 beers in a case, 24 hours in a day.
coincidence?
I think not.
first i unloosened everything then took out the brake, then just yanked off the lever xD
I just pretty much yanked everything off
i mean the guides that are welded to the frame that the cable runs through
lol 24 beers in a case, 24 hours in a day.
coincidence?
I think not.
oh, aren't those just stuck on the frame, some are removeable
yea some are removable
but the majority are TIG welded right onto the frame 24 beers in a case, 24 hours in a day.
coincidence?
I think not.
well your best bets gonna be just sawin them off, it doesnt take more than 5 minutes cause i did my friends before, make it a clean cut and itll look nice, and do the same for the cable guides get the hell off this site and go ride a fucking bike dammit!!!!!
i got a tranny silver finish
will i have to repaint the frame?
do you think a grinder might work? 24 beers in a case, 24 hours in a day.
coincidence?
I think not.
i wouldnt see why youd have to repaint it
and yeah a grinder might work, it might take longer though get the hell off this site and go ride a fucking bike dammit!!!!!
well my sawzall is a little dangerous at the moment
the blade hinge is broken
so i'm afraid the blade is gonna go flying when i turn the son of a bitch on 24 beers in a case, 24 hours in a day.
coincidence?
I think not.
Angle grinder with a cut off blade would be pretty good. Then you could put a regular grinding wheel on, and smooth it all out. Try not to generate too much heat, and don't grind a hole in your tubing.
cut threw it with a grinder then smooth it out with a grinder
but dont try and hit it off!!!!!! it leaves a hole in ya forks
i just got the haro convert frame so all i have to do is take every thing off......no cutting needed.
just leave the cable guides on there dude... obviously you don't know what your doing if ur thinkin about using a sawzall, and ya u would probly have to repaint the frame if u did because it would chip a lot of paint off. trust me, i tried that on an old frame i had... didn't work to well. -Jay
"this sport is 80% imagination, 20% money, and all about practice."
almost1148 wrote: okay i just got a new frame
