Chain Lubes
haro3001cody
Vital BMX member haro3001cody
109969 haro3001cody http://p.vitalbmx.com/photos/users/109969/avatar/c50_image_1390491058.jpg?1390490904 http://www.vitalbmx.com/community/haro3001cody,109969/all 01/23/14 http://www.vitalbmx.com/community/haro3001cody,109969/setup 2 5
8/9/2014 2:31 PM
what is everyones opinion on dry chain lubes? are they actually as good as wet lubes? or is there any difference
That Haro life
MidWestBMX
Vital BMX member MidWestBMX
112075 MidWestBMX http://p.vitalbmx.com/photos/users/112075/avatar/c50_MWBMX_1417735485.jpg?1417735256 http://www.vitalbmx.com/community/MidWestBMX,112075/all 06/28/14 2 http://www.vitalbmx.com/community/MidWestBMX,112075/setup 12 919 9 2
8/9/2014 3:13 PM
I have the white lightning dry lube stuff and it kinda sucks. it sorta keeps your chain cleaner but that dosen't matter to me, after a few days of it being applied it's dry and makes noise. I just use wd-40 even though it's a degreeser. just don't use it on your bearings
sundaybmxRR
Vital BMX member sundaybmxRR
8288 sundaybmxRR http://p.vitalbmx.com/photos/users/8288/avatar/c50_15102296_10210973470117928_1569641672_o_1479535352.jpg?1479534940 http://www.vitalbmx.com/community/sundaybmxRR,8288/all 07/13/07 233 223 114 http://www.vitalbmx.com/community/sundaybmxRR,8288/setup 335 11035 1227 20 662
8/9/2014 3:54 PM
MidWestBMX
8/9/2014 3:58 PM
sundaybmxRR wrote:
? what
sundaybmxRR
8/9/2014 4:15 PM
MidWestBMX wrote:
? what
WD40 is horrible for your chain, yes you can use it on your chain but then you must relube it right away. No lube = shitting drive train = more prone to breaking/making noises.
I assume you mean this stuff
Which in mine & a lot of other peoples opinions is one of the best chain lubes out there. Goes on nicely, doesn't leave a thick coat, and prevents dirt from being caked on. If your drive train is making noise then there's probably something else contributing to it, or you're not cleaning your chain. A good way to do that is to put some white lightning lube on the chain as you back pedal the bike a few times, take a rag and clean the chain off by holding onto the chain under the chainstays and backpedaling, then lube the chain up again. Works wonders with mine and my drive train is completely silent and doesn't attract dirt nearly as much as other lubes I've used.
Also, to answer your question OP, a dry lube like what I posted above (White lightning) works best in my opinion. Goes on a bit wet but dries up quickly and works nicely. I've used other lubes like 3 in 1 oil and while that feels like it lubes the chain more, it also attracts dirt and after awhile if you brush up against it, it leaves lube all over whatever you touched it with. I've used both, and after riding dirt jumps for 10 minutes, my chain was caked in dirt with the 3 in 1 oil. After riding dirt for at least 20 minutes using the white lightning, there was only a bit of dust on the chain.
As for what works best, I've had no problems with either aside from one attracting more dirt and the white lightning seems to last longer and doesn't need cleaned as often
MidWestBMX
8/9/2014 4:50 PM
Edited Date/Time: 8/9/2014 4:51 PM
since I started riding i've always used wd-40 on all my bikes, never snapped a chain for 3 years until I used this stuff for a few weeks. snapped a bluebird chain -_- Needless to say, i'm back on wd-40. When I was using clean ride, once it dried on it felt like there was sand in my chain. when i'm using wd, it just feels smoother and stays quiet. I'm not saying wd-40 is somehow better, but it hasn't failed me yet.
tomdon
Vital BMX member tomdon
91070 tomdon http://p.vitalbmx.com/photos/users/91070/avatar/c50_442481FCBF683345FAC307E0EF17B124E59D882A689BFC6EE3_pimgpsh_fullsize_distr_1421888027.jpg?1421887288 http://www.vitalbmx.com/community/tomdon,91070/all 02/29/12 8 http://www.vitalbmx.com/community/tomdon,91070/setup 148 5590 6 1 23
8/9/2014 4:56 PM
fuck chain lube
dave lawrence
Vital BMX member dave lawrence
20481 dave lawrence http://p.vitalbmx.com/photos/users/20481/avatar/c50_Skate_or_Leave_1466620531.jpg?1466620278 http://www.vitalbmx.com/community/dave-lawrence,20481/all 05/23/08 100 39 1 http://www.vitalbmx.com/community/dave-lawrence,20481/setup 243 17665 529 2 32
8/9/2014 5:18 PM
Gotta be something else contributing to the bluebird snap. Chain lube doesn't make them break. Period.
WD40 MAKES lubes, but just the general spray degreaser crap is a terrible choice as it removes lubrication, and leaves it dry. I STRONGLY recommend using something else.
I use FinishLine Dry Lube. Works great, doesn't attract dirt, and keeps things quiet.
I am sick and tired of the "cliques" that this sport has recently developed. We should embrace the fact that we all ride a little kids bike, and not worry about the small details. When you take riding in its most basic form, we are all the same.
haro3001cody
8/9/2014 6:43 PM
Yeah i bought some finishine dry lube. i used it on my chain and it just doesnt feel like its lubed, but thats the point. But i will continue to use it because i have no complaints, thanks
That Haro life
WoahD
Vital BMX member WoahD
111866 WoahD http://p.vitalbmx.com/photos/users/111866/avatar/c50_IMG_1480_1484926349.jpg?1484925617 http://www.vitalbmx.com/community/WoahD,111866/all 06/04/14 http://www.vitalbmx.com/community/WoahD,111866/setup 12 67 1
8/9/2014 6:48 PM
I use dry lubes but as far as wet lubes wd-40 works as well as any other. It is a cleaner but also contains several lubricants. People are on a bandwagon of thinking it's terrible for chains for some reason. Nothing wrong with using it on your chain. It is a lubricant.
huntsforbunz
Vital BMX member huntsforbunz
110474 huntsforbunz http://p.vitalbmx.com/photos/users/110474/avatar/c50_036_1402538754.jpg?1402538123 http://www.vitalbmx.com/community/huntsforbunz,110474/all 02/21/14 http://www.vitalbmx.com/community/huntsforbunz,110474/setup 36 201
8/9/2014 10:54 PM
i found out that jizz works great... i was just fapping and i didnt notice it hit my chain and man does that chain run smooth as hell
Brayden_Buckingham
Vital BMX member Brayden_Buckingham
82424 Brayden_Buckingham http://p.vitalbmx.com/photos/users/82424/avatar/c50_IMG_3612_1488929710.jpg?1488929592 http://www.vitalbmx.com/community/Brayden-Buckingham,82424/all 07/17/11 13 http://www.vitalbmx.com/community/Brayden-Buckingham,82424/setup 442 6294 267 10 7
8/9/2014 11:09 PM
Jizz and vagina slime
My S&M Bonesaw
My most recent edit : https://youtu.be/Pcbj3CuFv0g
"Pop a hard 180 into the dirt !" - Cam Swift
Doesn't matter if they ride scooters or rollerblades , we all just want to have fun
Mychaylo
Vital BMX member Mychaylo
108502 Mychaylo http://p.vitalbmx.com/photos/users/108502/avatar/c50_DSC00130_1406740018.jpg?1406739408 http://www.vitalbmx.com/community/Mychaylo,108502/all 10/21/13 7 1148 2 2
8/10/2014 7:48 AM
WD-40 is a displacement spray, it drives all the water out of grease and lubricant, it's intended for cleaning and then regreasing whatever you are using.
WoahD
8/10/2014 10:00 AM
Edited Date/Time: 8/10/2014 10:06 AM
#1............ It IS a Lubricant. Yes it's drives out water. Which almost all lubricants do. Unless they are water based. Which the only water based I ever heard of are sold in the planned parenthood section of walmart so I hope you aren't using sex lube on your chain.
sundaybmxRR
8/10/2014 2:32 PM
For the millionth time on this website, WD40 is NOT a lubricant. Yes it can be used in a pinch to lube something up, much like you can substitute a AAA battery for a AA battery (using aluminum foil to take up the gaps) but it will not yield the same results, won't last long at all, and you should replace if asap. WD40 is a solvent, meaning it removes grease & other things, and protects against rust. Go clean our your driver & bearings and replace them with just WD40 and see how long they last.
WoahD
8/10/2014 3:16 PM
Edited Date/Time: 8/10/2014 3:23 PM
I'm not gunna argue when I can Just read the can..... I've used it and know people that used it for years and NEVER had an issue.
If your chain chews up your driver you should get a better driver, new chain or align them better. No lube is gunna fix that lol
Mychaylo
8/10/2014 5:17 PM
Number 1 = lubricant, ok fair play it can be used if something's bound but not as a proper solution
Number 4 = Removes...grease? the prime lubricant on bikes?
Sweet, ima fill mah bearings with the lubricant removing lubricant.
Xxohioanxx
Vital BMX member Xxohioanxx
84146 Xxohioanxx http://p.vitalbmx.com/photos/users/84146/avatar/c50_47028_101011776630841_132097_n_1438878770.jpg?1438878611 http://www.vitalbmx.com/community/Xxohioanxx,84146/all 08/27/11 12 http://www.vitalbmx.com/community/Xxohioanxx,84146/setup 58 5310 58 17 5
8/10/2014 5:22 PM
I use WD40 instead of grease, anti-seize, and lube because I can read and science.
YOU AVIN A LAUGH M8?
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
The Trailest Bike On Vital
Mychaylo
8/10/2014 5:25 PM
I once ran out of wax and used it on this ledge. Best. Feeb. Ever.
Xxohioanxx
8/10/2014 5:29 PM
I once ran out of dick and used this on my girlfriend. Penetrated her perfectly. It also displaced all the moisture.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
K_A_N_E_
Vital BMX member K_A_N_E_
106758 K_A_N_E_ http://p.vitalbmx.com/photos/users/106758/avatar/c50_1908376_743429109054852_4480160112521288533_n_1408568840.jpg?1408568630 http://www.vitalbmx.com/community/K-A-N-E,106758/all 07/06/13 3 http://www.vitalbmx.com/community/K-A-N-E,106758/setup 91 1441 14 2
8/10/2014 5:40 PM
What ever grease is in my shed, most of the time it leaves a think black gunk on my driver
I'm gonna need bigger bars
bmxsteve99
Vital BMX member bmxsteve99
104707 bmxsteve99 http://p.vitalbmx.com/photos/users/104707/avatar/c50_vital5.17.15_1431899110.jpg?1431899062 http://www.vitalbmx.com/community/bmxsteve99,104707/all 04/14/13 83 3835 2 3
8/10/2014 5:44 PM
i really dont lube my chain much, a quick spray of wd40 or silicone lubricant, never had any problems or funny noises whatsoever
sundaybmxRR
8/10/2014 5:44 PM
brb, removing all the grease in my bearings/driver with the de-greaser known as WD40, then replacing it with the lubricant (according to WoahD) WD40
Wait a second...
WoahD
8/10/2014 8:05 PM
Edited Date/Time: 8/10/2014 8:19 PM
Wait a second...
Your comparing apples to oranges. Wd40 is an oil, it is not grease. You grease bearings... And you oil chains. It's very simple. You wouldn't put white lightning chain lube on your bearings... Does that mean it's not good for your chain either? No one said grease your bottom bracket or wheels with Wd40. You don't put bearing grease on your chain, does that mean it won't work on your bb either?? Just because it doesn't work on your BB doesn't mean it won't work on your chain. They are totally different.
bmxsteve99
8/10/2014 8:12 PM
Wait a second...
this
grease gives hubs more reliable resistance that a light oil
in rc car differentials, you can use silicone oil, which is extremely inconsistent or grease, guess which one everyone uses?
WoahD
8/10/2014 8:25 PM
Wait a second...
bmxsteve99 wrote:
this
Now your comparing 2 totally different things. On a totally different subject. This isn't vitalRC. I'm talking about bikes. Idk anything about rc cars and have no interest in them. If that silicone stuff is so good for stuff go lube your whole bike up with it. Chain, bb, headset, wheels, seat tube, grips, seat, and tires too don't wanna miss any swag points when you power slide.
Xxohioanxx
8/10/2014 8:27 PM
bmxsteve99 wrote:
this
But on roller coaster wheels they grease and then lube, then spray in jizz, that matters.
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
bmxsteve99
8/10/2014 8:27 PM
bmxsteve99 wrote:
this
what i am saying is that an enclosed area with moving parts is best filled up with grease
WoahD
8/10/2014 8:30 PM
Edited Date/Time: 8/10/2014 8:34 PM
bmxsteve99 wrote:
this
I agree 100% with that, didn't read your first post correctly. I thought it was Sundaybmxrr arguing that the oil would be better for hubs. Lol my bad.
isnowyaznV2
Vital BMX member isnowyaznV2
95706 isnowyaznV2 http://p.vitalbmx.com/photos/users/95706/avatar/c50_360_out_of_the_bank_Wackford_1449123362.jpg?1449122596 http://www.vitalbmx.com/community/isnowyaznV2,95706/all 06/29/12 11 http://www.vitalbmx.com/community/isnowyaznV2,95706/setup 183 4705 29 30 5
8/10/2014 11:19 PM
I remember when I first started riding, I hated grease mainly cause it was dirty. Now, I put the slightest bit of grease on nearly everything, except things like my seatpost. I also remember making a thread telling everyone I used sex lube my cassette hubs, and it's NOT a lie, haha. I still do to this very day, Astroglide ftw! But on a serious note, soaking my chains in motor oil or just slathering every inch of the chain in white lithium grease does the job. But yeah, common sense tells you to dry off excess as much as possible, or else the chain does even worse being dirty than just being dry.
