How do I take them off?
___ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡π̲̲͡|̡̡̡____
This is Bob and his beautiful beach house, copy and paste him on your signature so he can obtain Vital domination!
Bike check?
Proverbs 3:5-6
Do I just cuz a hole in the center of them or cut the straight off to the grip?cupovjoe wrote: you ride them till the bars punch holes through or cut them off
Proverbs 3:5-6
Proverbs 3:5-6
thats pretty good ideaDrnwagn wrote: I said, tap! Not bang! This will leave the nice finished round edges of the grip in tact but cut a perfect hole the size of the bar to allow the barend to plug into.
Proverbs 3:5-6
OH ok thanks and how do you install the grips cuz the ziptie way won't workDrnwagn wrote: Put the grip on the bar. Take a hammer and tap around the bar end. The pressure between the hammer and the handle bar will cut a perfect circle in the end of the grip. Remove the little round piece of grip, insert new barend and your done!
No cuz then the barends will be sitting on the left over built in barendDrnwagn wrote: I said, tap! Not bang! This will leave the nice finished round edges of the grip in tact but cut a perfect hole the size of the bar to allow the barend to plug into.
Proverbs 3:5-6
How long does it take to dry?Drnwagn wrote: WHAT??? What do you mean ZIP Tie???
Seriously, get some hair spray, alcohol (don't mean a beer either) or even spit (takes longer to dry though) and wet the inside of the grips. Put a little on the bar. Slide it on.
If you really want to ride right away and they are still wet, you can take a screw driver (phillips--the one that looks like a plus on the end) and slip it under the grip to create a pocket (between the grip and the bar) and hold a hair dryer on it to help dry it out. Pull the screw driver out and go play. Repeat if needed.
Proverbs 3:5-6
Proverbs 3:5-6
Ok I will try it your wayDrnwagn wrote: Click on my avatar picture. You can see what mine look like. Mine have a flare at the end which is what yours would probably end up looking like. Sort of a natural stop for your hand if you will. Same principle as to why the head on your penis is bigger than the shaft fool. Too keep your hand from flying off!
Seriously, if you don't like the way that looks then you can simply take a box knife or razor blade and cut the whole end off. This in affect shortens the grip though. it is totally up to you.
bmx214 wrote: My Longnecks didn't have a solid end... I'm confused... what are you talking about! I installed my grips and put fit bar ends on without having to do anything... ???
Proverbs 3:5-6
weird... I had no idea they were coming like that now... mine came with plastic plug style ODI bar ends. And DrnWagn is totally correct on the grip installation. That's exactly how I installed mine... I even did the screwdriver / hairdryer trick cuz I used too much hairspray and it was taking forever to dry, LOL! ...and here I thought I had come up with this great idea, turns out that's common knowledge, lol.Zachy D wrote:
They have barends at the end
Proverbs 3:5-6
Proverbs 3:5-6
Proverbs 3:5-6
