New Forum Topic
Forum Main ›› General BMX Talk ›› Stripped Stem Bolts
Vital BMX member jmoney
Vital BMX member jacobbmx013
Vital BMX member curly
Stripped Stem Bolts
jmoney
Louisville, KY
Quote this post
5/9/2008 5:07 PM
5/9/2008 5:22 PM
I was going to replace my forks and when I tried to loosen one of the allen bolts it stripped out real bad. The bolt sits flush into the stem and is in there really tight so I don't really want to try and use an easy-out because it will probably just break off in the bolt. Any suggestions anyone?
jacobbmx013
Richmond, VA
Quote this post
5/9/2008 5:13 PM
what about them??
they cant be fixed
well, i guess if you bought a tap you could fix them
but i would say just buy a new stem because re-threding them is sketchy
curly
Orlando, FL
Quote this post
5/9/2008 7:31 PM
you probably pinched your stem shut if you cant get the bolts out without stripping them
jmoney
Louisville, KY
Quote this post
5/9/2008 7:33 PM
The threads in the stem aren't stripped, it is just the 2nd bolt that holds the stem tight onto the forks. I am going to take it up to Lowes and ask them what I should do.
If there is an allen wrench that is between 7/32 and 1/4 of an inch I am good to go but I can't find one.
Post a Reply to: Stripped Stem Bolts
Please log in in order to comment.
