Tips for beginner at grinding
p0cketz_98
Vital BMX member p0cketz_98
112423 p0cketz_98 /images/default/avatar/c50.png http://www.vitalbmx.com/community/p0cketz-98,112423/all 07/30/14 11 3
7/30/2014 8:29 PM
I recently started grinding, i can hop into most grinds but i have a hard time staying into them and hopping out. Any tips or tricks that will help?
Xxohioanxx
Vital BMX member Xxohioanxx
84146 Xxohioanxx http://p.vitalbmx.com/photos/users/84146/avatar/c50_47028_101011776630841_132097_n_1438878770.jpg?1438878611 http://www.vitalbmx.com/community/Xxohioanxx,84146/all 08/27/11 12 http://www.vitalbmx.com/community/Xxohioanxx,84146/setup 58 5311 58 17 5
7/30/2014 8:31 PM
Lean into the grind more if you're falling off. This is one of the things I see people messing up a lot. You have to lean in more than you think. And to get off, just go faster and it'll make it way easier. That sounded really inappropriate but you get the point.
YOU AVIN A LAUGH M8?
┬┴┬┴┤ ( ͡° ͜ʖ├┬┴┬┴
The Trailest Bike On Vital
buttmeate
Vital BMX member buttmeate
96033 buttmeate http://p.vitalbmx.com/photos/users/96033/avatar/c50_bigbag.jpg?1341687893 http://www.vitalbmx.com/community/buttmeate,96033/all 07/07/12 176 http://www.vitalbmx.com/community/buttmeate,96033/setup 50 258 33 3 3
7/30/2014 8:32 PM
Go fast
balance your feebles
doublepegs are hard to lock into
staying in a smith takes a special technique that I only had for a week, but 20ft long smiths are possible
ice picks are like learning Manuela all over again but much more difficult
wallride a bus everyday
ThugLifeBmxRiderz
Vital BMX member ThugLifeBmxRiderz
106733 ThugLifeBmxRiderz http://p.vitalbmx.com/photos/users/106733/avatar/c50_balls_1373956045.jpg?1373955387 http://www.vitalbmx.com/community/ThugLifeBmxRiderz,106733/all 07/04/13 http://www.vitalbmx.com/community/ThugLifeBmxRiderz,106733/setup 84 730 2 3 1
7/31/2014 1:03 AM
Dont fall
Bang Bang bmx
urebmx
Vital BMX member urebmx
112326 urebmx http://p.vitalbmx.com/photos/users/112326/avatar/c50_DSC00468_1407247418.jpg?1407246711 http://www.vitalbmx.com/community/urebmx,112326/all 07/20/14 3 99
7/31/2014 6:59 AM
just keep trying any grind you feel good doing. for most folks thats gonna be a feeble grind. youll figure it out and when you do it will help you do other grinds as well. leaning forward helps and sometimes i twist my body to help stay locked in.
i ride to stay young
transition_chris
Vital BMX member transition_chris
109466 transition_chris http://p.vitalbmx.com/photos/users/109466/avatar/c50_transition_fb_logo_1388275345.jpg?1388274353 http://www.vitalbmx.com/community/transition-chris,109466/all 12/28/13 1 http://www.vitalbmx.com/community/transition-chris,109466/setup 22 628
7/31/2014 9:03 AM
Edited Date/Time: 7/31/2014 9:03 AM
For feebles it really helps to keep your front tire as close to the edge of the ledge as possible.
Double pegs, I just think about getting my front peg on and then my back will follow.
Smith grinds, think about putting your back tire down on the ledge in the right spot.
Crooked grinds, go fast, for some reason it helps lock them in.
Also, get good hub guards like the S&M Cymbal guards. Not only do they protect your hubs and spokes, but they also help lock in your grinds!
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
lbphillyrider
Vital BMX member lbphillyrider
111690 lbphillyrider /images/default/avatar/c50.png http://www.vitalbmx.com/community/lbphillyrider,111690/all 05/21/14 1 http://www.vitalbmx.com/community/lbphillyrider,111690/setup 2 65 3 1
7/31/2014 9:47 AM
All really good tips here but most important is keeping your weight balanced over whatever it is your grinding on. If your hopping on and falling right off, your leaning away from it..keep your weight centered over it and you'll notice you'll start to lock it in and slide further..you also have to get over the fear of hopping on stuff like that..just pick a spot to aim your front peg at and do it..really that's the biggest thing when you first start grinding
isnowyaznV2
Vital BMX member isnowyaznV2
95706 isnowyaznV2 http://p.vitalbmx.com/photos/users/95706/avatar/c50_360_out_of_the_bank_Wackford_1449123362.jpg?1449122596 http://www.vitalbmx.com/community/isnowyaznV2,95706/all 06/29/12 11 http://www.vitalbmx.com/community/isnowyaznV2,95706/setup 183 4705 29 30 5
7/31/2014 12:51 PM
Keeping balance is the most important part. Learning double pegs first can be hard, but it's rewarding. I learned feebles first like most people, and now it's hard trying to dial in double pegs because you're so used to the front end going straight up onto whatever you're grinding out of instinct. But yeah, wax and metal pegs and some speed are good things. Don't go with the trend and get plastic or plastic-sleeved pegs starting off because they might slide too easily. Just use common sense for some things, such as not full on nose-diving into a smith or double peg onto a rough surface that can barely slide.
Stocksy
Vital BMX member Stocksy
106345 Stocksy http://p.vitalbmx.com/photos/users/106345/avatar/c50_Tops_1439789482.jpg?1439788828 http://www.vitalbmx.com/community/Stocksy,106345/all 06/18/13 3 1 http://www.vitalbmx.com/community/Stocksy,106345/setup 156 2245 1
7/31/2014 12:57 PM
Everything said by everyone else and make sure that the rail or ledge is very well waxed.
YouTube
Edit
FaceBook (Still Wock)
Twitter (@WillStockSucks)
Instagram (@WillStockSucks)
bmxfromma
Vital BMX member bmxfromma
80745 bmxfromma http://p.vitalbmx.com/photos/users/80745/avatar/c50_image_1396922041.jpg?1396921447 http://www.vitalbmx.com/community/bmxfromma,80745/all 06/13/11 102 1696 19 1 3
7/31/2014 5:57 PM
I can't tell you how many people I see that try to feeble and their front tire goes a foot from the edge and they don't know why they keep falling off.
KEEP YOUR DAMN FRONT TIRE AS CLOSE TO THE EDGE/COPING AS POSSIBLE
-HardBMX_Tim
