Tubes popping at 70 psi
bikesandbeaches_yo
Vital BMX member bikesandbeaches_yo
108793 bikesandbeaches_yo http://p.vitalbmx.com/photos/users/108793/avatar/c50_10614279_842675175757139_1950386662502216914_n_1408552309.jpg?1408551338 http://www.vitalbmx.com/community/bikesandbeaches-yo,108793/all 11/08/13 1 http://www.vitalbmx.com/community/bikesandbeaches-yo,108793/setup 14 73 2
8/20/2014 9:04 AM
Just picked up a new Animal GLH tire which has a 110 psi rating and every time i start blowing it up, at around 68-70 psi the inner tube blows out. I've tried 3 tubes already and all of them blew out. Does anyone know why this might be happening?
"The best activities for your health are humping and pumping" - Vladimir Putin
BMX Gallery 4130, Transition Bmx, Dan's Comp
tomdon
Vital BMX member tomdon
91070 tomdon http://p.vitalbmx.com/photos/users/91070/avatar/c50_442481FCBF683345FAC307E0EF17B124E59D882A689BFC6EE3_pimgpsh_fullsize_distr_1421888027.jpg?1421887288 http://www.vitalbmx.com/community/tomdon,91070/all 02/29/12 8 http://www.vitalbmx.com/community/tomdon,91070/setup 148 5585 6 1 23
8/20/2014 9:09 AM
what tubes are you using?
bikesandbeaches_yo
8/20/2014 9:16 AM
ones from my lbs, not sure
tomdon
8/20/2014 9:17 AM
Taht's weird that they keep popping at 70psi. Try using a tube from somewhere else and see if the problem persists
handlebar-to-face
Vital BMX member handlebar-to-face
103879 handlebar-to-face http://p.vitalbmx.com/photos/users/103879/avatar/c50_s_m_gravity_400pix_1370722046.jpg?1370721875 http://www.vitalbmx.com/community/handlebar-to-face,103879/all 03/12/13 1 101 4684 2
8/20/2014 9:18 AM
Edited Date/Time: 8/20/2014 9:19 AM
Your PSI gauge might be fucked, giving a lower reading?
THOU SHALL NOT COMMIT SKOOTERY
Murica bike check
text me323.245.2827
bmxsteve99
Vital BMX member bmxsteve99
104707 bmxsteve99 http://p.vitalbmx.com/photos/users/104707/avatar/c50_vital5.17.15_1431899110.jpg?1431899062 http://www.vitalbmx.com/community/bmxsteve99,104707/all 04/14/13 83 3835 2 3
8/20/2014 9:18 AM
either the tubes arent designed for that high psi, you arent seating them correctly, or they are just shit
bikesandbeaches_yo
8/20/2014 9:36 AM
could be that. not too sure though.
bikesandbeaches_yo
8/20/2014 9:37 AM
tried a shitty bell tube too and it popped
Kokxxy
Vital BMX member Kokxxy
112572 Kokxxy http://p.vitalbmx.com/photos/users/112572/avatar/c50_images_1461084522.jpg?1461083585 http://www.vitalbmx.com/community/Kokxxy,112572/all 08/15/14 7 487
8/20/2014 9:48 AM
Edited Date/Time: 8/20/2014 9:49 AM
Pump till solid and if it hasnt popped let it sit and the tire adjust to pressure being on it? I bought a brand new tire one time and went straight to 110 psi and blew out some of the bead and ruptured the tire on the middle of the tread after about a month. Im superstitious about some stuff though.
"It's like riding someone's bike and they got the same frame" -Four
Refs:Four x4,tomdon x5,Xxohioanxx,BigCurn, Don't remember the rest
iFit
Vital BMX member iFit
111098 iFit http://p.vitalbmx.com/photos/users/111098/avatar/c50_image_1408144275.jpg?1408143974 http://www.vitalbmx.com/community/iFit,111098/all 04/05/14 41 145 2
8/20/2014 9:55 AM
Rim pinch
We out here breathing. -Bert
bikesandbeaches_yo
8/20/2014 9:58 AM
Okay thanks I'll try it out.
bmxsteve99
8/20/2014 10:00 AM
iFit wrote:
Rim pinch
probably this
Kokxxy
8/20/2014 10:02 AM
iFit wrote:
Rim pinch
This too. Make sure that you don't twist the tube, Pinch it in anyway, the tire doesn't have a cord/thread showing from a defect or something &also be certain that there isn't anything sharp around the valve stem hole on the rim or on the rim in general.
bmxsteve99
8/20/2014 10:08 AM
iFit wrote:
Rim pinch
might be a good idea to use an air compressor to blow out any debris still clinging onto the inside of the tire and rim
iFit
8/20/2014 4:32 PM
Or you may need a rim strip because your spokes and or nipples maybe puncturing your tube.
MidWestBMX
Vital BMX member MidWestBMX
112075 MidWestBMX http://p.vitalbmx.com/photos/users/112075/avatar/c50_MWBMX_1417735485.jpg?1417735256 http://www.vitalbmx.com/community/MidWestBMX,112075/all 06/28/14 2 http://www.vitalbmx.com/community/MidWestBMX,112075/setup 12 919 9 2
8/20/2014 4:36 PM
why would you need more than 60 psi anyway?
transition_chris
Vital BMX member transition_chris
109466 transition_chris http://p.vitalbmx.com/photos/users/109466/avatar/c50_transition_fb_logo_1388275345.jpg?1388274353 http://www.vitalbmx.com/community/transition-chris,109466/all 12/28/13 1 http://www.vitalbmx.com/community/transition-chris,109466/setup 22 628
8/20/2014 4:41 PM
It sounds like the tire is not seated properly in the rim. Did you buy the tires from us? If so, next time just give us a call if you need help!
The most important part is to make sure the bead is fully seated in the rim. To do this, inflate your tire to around 10 PSI and then rock it back and forth on the rim to make sure it is seated properly. Inflate a little bit more and then repeat. If the bead has slipped out when you were inflating the tire, check it for damage. If it is torn you may need a new tire.
Chris
www.bmxtransition.com
Canadian BMX Mailorder
Instagram: @transitionbmx
Stocksy
Vital BMX member Stocksy
106345 Stocksy http://p.vitalbmx.com/photos/users/106345/avatar/c50_Tops_1439789482.jpg?1439788828 http://www.vitalbmx.com/community/Stocksy,106345/all 06/18/13 3 1 http://www.vitalbmx.com/community/Stocksy,106345/setup 156 2245 1
8/20/2014 6:24 PM
Make sure the bead of the tire is correctly positioned. I've blown out a few tubes because I beaded a tire wrong.
YouTube
Edit
FaceBook (Still Wock)
Twitter (@WillStockSucks)
Instagram (@WillStockSucks)
bikesandbeaches_yo
8/20/2014 6:34 PM
Ah I think thats it. Thanks a lot for the help. And no I bought it from Cyclepath Calgary. But have ordered stuff from you guys in the past. Great service, love your shop.
dave lawrence
Vital BMX member dave lawrence
20481 dave lawrence http://p.vitalbmx.com/photos/users/20481/avatar/c50_Skate_or_Leave_1466620531.jpg?1466620278 http://www.vitalbmx.com/community/dave-lawrence,20481/all 05/23/08 98 39 1 http://www.vitalbmx.com/community/dave-lawrence,20481/setup 240 17476 527 2 32
8/20/2014 6:50 PM
Inspect the tire bead, the rim and find where the tubes pop. That will help narrow down what they issue is. Then correct it. I would bet you pinched the tubes.
I am sick and tired of the "cliques" that this sport has recently developed. We should embrace the fact that we all ride a little kids bike, and not worry about the small details. When you take riding in its most basic form, we are all the same.
adamnmexican
Vital BMX member adamnmexican
105254 adamnmexican http://p.vitalbmx.com/photos/users/105254/avatar/c50_mexican_zoidberg_avatar_picture_12392_1367775905.jpg?1367775581 http://www.vitalbmx.com/community/adamnmexican,105254/all 05/05/13 1 3 http://www.vitalbmx.com/community/adamnmexican,105254/setup 34 1565 4 4
8/20/2014 7:19 PM
This
fack off
isnowyaznV2
Vital BMX member isnowyaznV2
95706 isnowyaznV2 http://p.vitalbmx.com/photos/users/95706/avatar/c50_360_out_of_the_bank_Wackford_1449123362.jpg?1449122596 http://www.vitalbmx.com/community/isnowyaznV2,95706/all 06/29/12 11 http://www.vitalbmx.com/community/isnowyaznV2,95706/setup 183 4704 29 30 5
8/20/2014 8:15 PM
adamnmexican wrote:
This
Might as well ask all the people who run breaks, freecoaster hubs, and/or pegs and why they need them..
bmxsteve99
8/20/2014 8:54 PM
i cant stand anything below 50 or so, feels waterlogged and sluggish
70-80 for everything is nice imo
motomonkey
Vital BMX member motomonkey
53065 motomonkey http://p.vitalbmx.com/photos/users/53065/avatar/c50_Project1_1472587187.jpg?1472586647 http://www.vitalbmx.com/community/motomonkey,53065/all 11/01/09 http://www.vitalbmx.com/community/motomonkey,53065/setup 4 152 14
8/21/2014 7:20 AM
check to see if there is something in the tire and check the rimstrip for a hole.
something sharp is probably in there causing the puncture.
find out where the hole is and look at the corresponding area in the rim/tire.
hope this helps!
Kokxxy
8/21/2014 7:23 AM
I also put baby powder in my tires to reduce friction and pinch flats not really gonna help you here though.
dave lawrence
8/21/2014 11:17 AM
This.
I weigh 245 lbs give or take depending on if I pooped, and I run 80 MAX on the BMX. Usually I air em up once a month or so (I don't ride a lot these days).
