Wippermann Connex 1R8 G-Sport Ratchet
jamiespadina
Vital BMX member jamiespadina
103681 jamiespadina http://p.vitalbmx.com/photos/users/103681/avatar/c50_air_1413434584.jpg?1413433917 http://www.vitalbmx.com/community/jamiespadina,103681/all 03/06/13 1 2 http://www.vitalbmx.com/community/jamiespadina,103681/setup 95 1442 7 11
5/21/2014 4:59 PM
Hey thinking about finally buying a wippermann chain but I run a Ratchet. As some of you may know not alot of beefy chains will run on this chain well. Does anyone know if this or the KMC 415H Street chain will fit or am I pushing my luck? Thanks
BNC
Vital BMX member BNC
97074 BNC http://p.vitalbmx.com/photos/users/97074/avatar/c50_picasso_drawing_head.jpg?1364414494 http://www.vitalbmx.com/community/BNC,97074/all 08/06/12 37 749 1
5/21/2014 5:37 PM
Edited Date/Time: 5/21/2014 5:37 PM
Ran that combo for likr 2 years its noisy at firts but it works (wippermann 1r8)
Check my bike check its on there
HardBMX_Tim
Vital BMX member HardBMX_Tim
106966 HardBMX_Tim http://p.vitalbmx.com/photos/users/106966/avatar/c50_IMG_41431155304659_1415905782.jpg?1415905117 http://www.vitalbmx.com/community/HardBMX-Tim,106966/all 07/15/13 3 297 4824 7
5/21/2014 5:38 PM
Going off of Chuck's Ratchet and 1g8, it WILL work but you will have to run a 10t driver and file the teeth on it. The pins will also rub the hubshell, but after it wears a small groove into the hubshell it will work no problems.
415H has slightly wider pins than the 1g8 so it would rub the shell too much to function properly.
I suggest just getting the Keychain, it drops May 27 and Empire is accepting pre-orders NOW.
HardBMX_Tim
5/21/2014 5:42 PM
Sorry didn't see you said 1r8. 1r8 should work fine .
jamiespadina
5/21/2014 5:54 PM
Alright cheers guys, Used to have the 415H street on my mix and it was amazingly strong then It went missing and sinch then i just snap chains every now and then. Will gret the wippermann
Thanks again for all the help
Chuck8273
Vital BMX member Chuck8273
86726 Chuck8273 http://p.vitalbmx.com/photos/users/86726/avatar/c50_image_1378092142.jpg?1378091187 http://www.vitalbmx.com/community/Chuck8273,86726/all 11/03/11 14 15 http://www.vitalbmx.com/community/Chuck8273,86726/setup 67 5740 11 2 10
5/22/2014 9:12 AM
Due to the longer distance between the roller and edge of the link, the 415h will not mesh properly with any driver that has shoulders on either side of the teeth. I would definitely steer clear of that thing. The pins are also wider, as Timmay! said.
