New Forum Topic
Forum Main ›› General BMX Talk ›› does wd-40 work as chain grease?
Vital BMX member ridebmx925
Vital BMX member easymoney66
Vital BMX member th3skyizthalimit
Vital BMX member NOR*CAL
Vital BMX member Kenny Stanley
Vital BMX member iBike
Vital BMX member ethan.bmx
Vital BMX member whitey
Vital BMX member Jamie Girven
Vital BMX member dalton_
Vital BMX member sundaybmxRR
Vital BMX member GutturalGuy40
Vital BMX member reaperrider13
Vital BMX member aussie_pride
Vital BMX member peoplethewe
ridebmx925
Livermore, CA
Quote this post
5/11/2008 5:16 AM
my freakin chain is makin a hella annoying sound, its very tite but still makes sound. It is the only thing tha makes sound on my bike and that pisses me off. So ya if you want you can tell me if it works
easymoney66
ROANOKE, VA
Quote this post
5/11/2008 5:21 AM
yea, it works fine, but it doesnt last as long as the more expensive lubricants from the bike shop
th3skyizthalimit
HUNTINGTON STATION, NY
Quote this post
5/11/2008 5:22 AM
its ment more for cleaning or getting rust off
NOR*CAL
Yreka, CA
Quote this post
5/11/2008 5:30 AM
yea it works...get tri flow insted tho...shits good
Kenny Stanley
Rifle, Co
Quote this post
5/11/2008 5:32 AM
yup
iBike
Garden Grove, CA
Quote this post
5/11/2008 5:40 AM
i heard its bad cause it gets dirt stuck to it
ethan.bmx
g town,
Quote this post
5/11/2008 8:16 AM
it stoped the squiking on my bike
whitey
Bunbury, AUS
Quote this post
5/11/2008 9:14 AM
I wouldnt use it because it will wash all the other grease out. If u have brought a new sprocket or driver and kept the same chain that would be why. Because if you change a driver or sprocket you need to change the chain to.
Jamie Girven
Manchester,
Quote this post
5/11/2008 9:17 AM
wd 40 is a water displacer , it gets rid of water and prevents rust,
ye itll work, but only for a couple of days.
gt85 is kind of the same, but is specificaly for bicycles.
dalton_
Fairfield, OH
Quote this post
5/11/2008 2:29 PM
wd 40 is a de-greaser, which means its helps take grease off, in turn making your chain squeak more.
sundaybmxRR
hanover, PA
Quote this post
5/11/2008 3:24 PM
use carburetor fluid, i used that and mine works perfect
GutturalGuy40
WILLIAMSPORT, PA
Quote this post
5/11/2008 4:34 PM
NOR*CAL wrote: yea it works...get tri flow insted tho...shits good
Listen to this guy, tri-flow works amazingly
reaperrider13
BAKERSFIELD, CA
Quote this post
5/12/2008 3:14 AM
tri flow and having your chain tight can also be a culprit
aussie_pride
taree, AUS
Quote this post
5/12/2008 3:24 AM
tri flow is the best or any telfon based lubricants or ice wax ur local should have that if they dont ehy dont no what tehre on about
peoplethewe
Renton, WA
Quote this post
5/12/2008 5:35 AM
wd 40 is water based and comes off easily. get a good chain grease from your shop, its worth the couple dollars
Post a Reply to: does wd-40 work as chain grease?
Please log in in order to comment.
