what to learn after a bunny hop ?
pagosapunk
Vital BMX member pagosapunk
18920 pagosapunk http://p.vitalbmx.com/photos/users/18920/avatar/c50_629727668_1211548389.jpg?1293057843 http://www.vitalbmx.com/community/pagosapunk,18920/all 04/26/08 2 2 6 1 2
5/3/2008 4:42 PM
hey,
Learned the bunny hop about a week ago . Can get it up to 1 foot . I can also front pull and hiphop . I ride street mostly . whats the next easiest trick to learn ?
TodyJohnson
Vital BMX member TodyJohnson
19204 TodyJohnson /images/default/avatar/c50.png http://www.vitalbmx.com/community/TodyJohnson,19204/all 05/01/08 2 6 26
5/3/2008 5:07 PM
From what I hear, your best bet at a new trick would be a 180.
quiktrip
Vital BMX member quiktrip
15619 quiktrip http://p.vitalbmx.com/photos/users/15619/avatar/c50_114904560_1233344282.jpg?1293050065 http://www.vitalbmx.com/community/quiktrip,15619/all 02/10/08 8 2 http://www.vitalbmx.com/community/quiktrip,15619/setup 3 69 37 10
5/3/2008 5:19 PM
540 you know thats about it
patrick clark
Vital BMX member patrick clark
11802 patrick clark http://p.vitalbmx.com/photos/users/11802/avatar/c50_cherry_11.jpg?1305266418 http://www.vitalbmx.com/community/patrick-clark,11802/all 11/11/07 129 25 1 http://www.vitalbmx.com/community/patrick-clark,11802/setup 9 53 143 1 37
5/3/2008 5:29 PM
backflip
haha nah probablly 180's and manuals
bmxrules7
Vital BMX member bmxrules7
6038 bmxrules7 http://p.vitalbmx.com/photos/users/6038/avatar/c50_129489550_1249674163.jpg?1293029617 http://www.vitalbmx.com/community/bmxrules7,6038/all 04/10/07 1 4 1 1 56
5/3/2008 5:34 PM
180's and manuals
posably barspins too
pagosapunk
5/3/2008 5:50 PM
huh....just tried to manule...dont use pegs so its kinda hard(assume you put your feet on back pegs) I have no ide how im gona 180 its looks so hard....are there easier tricks that work up to it ? thats how i learned to bunny hop . and I ride 1 break no detanglar so I can't really do barspins.....
04wildman
Vital BMX member 04wildman
18973 04wildman http://p.vitalbmx.com/photos/users/18973/avatar/c50_635639368_1217930323.jpg?1293057992 http://www.vitalbmx.com/community/04wildman,18973/all 04/27/08 21 7 2 46 873 293 16 5
5/3/2008 5:59 PM
Find a nice gradually down sloped "hill" Manual with your feet on the pedals ( same way as when you bunny hop). Then bunny hop on to a curb and gradually lean farther and farther back and learn to hop onto a curb into a manual and then find a quarter pipe the ride up and role out fakie (backwards) Back pedal and just try to go in "rewind" Then learn how to turn it around doing a Fakie. I'm sure people here can help with all of these basics.
unluckyrider
Vital BMX member unluckyrider
18902 unluckyrider http://p.vitalbmx.com/photos/users/18902/avatar/c50_630284668_1209236381.jpg?1293057817 http://www.vitalbmx.com/community/unluckyrider,18902/all 04/26/08 3 8 86 21 1 2
5/3/2008 6:07 PM
ye im with pago on this, im new at BMXing and i kno how to bunnyhop too... but i dont see how a 180 is easy from there
04wildman
5/3/2008 6:12 PM
Once you get tired or frustrated with one, switch to another. Find one spot that has "the subtle hill", "island curb's or similar set up", and set up a box or something WEAK that you can bunny hop over", and just run it like a drill. Some times you can find a steep bank at a loading dock and use it as a quarter pipe for getting "reverse momentum" before trying any bunny hop 180's. That way you know how to ride backwards and do Fakies before your 180;s. Setting you up for landing your 180's and more. You will also be set up for powerslide "to fakie" and 360's and also tire taps to Fakies at parks. These are all Fundamental and easy to bail from clean. Stay loose!
TodyJohnson
5/3/2008 6:14 PM
Well considering I'm newer than both of you, I'm not very good reference but I would suggest finding some grass to start. Go ahead and get a small rolling start or none at all. Lean your head to the side you'd like to 180 towards. Kind of whip your head but not to hard because well it could mess your neck up. Lift the front tire and hop. Kind of a bunny hop with a small rolling start. Just make sure to throw your head into the direction you wish to turn. You may not be able to go all the way around at first but after enough tries and practice, I'm sure you'll get there. The reason I suggest grass is so if you hit it doesn't hurt as bad.
lostboys
Vital BMX member lostboys
16097 lostboys http://p.vitalbmx.com/photos/users/16097/avatar/c50_116039720_1238595524.jpg?1293051517 http://www.vitalbmx.com/community/lostboys,16097/all 02/22/08 14 4 http://www.vitalbmx.com/community/lostboys,16097/setup 18 130 13 1 11
5/3/2008 6:21 PM
180s are easy. just carve turn your head and hop. but the fakie is a different story
pedal harder hop higher and try new stuff this is bmx
04wildman
5/3/2008 6:35 PM
Fakie's are so fucking easy with brakes! Took me 6 tries, and in both directions. Next day after hours of work I was doing the tire tap to fakie on one side of a four foot box jump. If you are athletic at all you can spin out of a fakie with out tripping on you're bike! 180's can tweek your body and leave you unable to work on FAKIES, MANUALS, BUNNYHOPPING, AND HOPPING ON CURBS INTO MANUALS. I suggest doing those drills even after learning the shit. Just keep hopping higher boxes, and hopping into manuals on higher and higher curbs and ledges. And trust me FAKIES ARE EASY! You don't NEED to 180 in. Thats what the tire tap is for. You don't start out with tiretaps, you can just "reverse gears" keep your weight off the bars and lay her down to one side or the other after you ride backwards for 6-8-10 yards. No high impacts in any of this. Its just fundamental conditioning.
ethan.bmx
Vital BMX member ethan.bmx
18892 ethan.bmx http://p.vitalbmx.com/photos/users/18892/avatar/c50_105500260_1236857530.jpg?1293057802 http://www.vitalbmx.com/community/ethan-bmx,18892/all 04/26/08 2 24 7 http://www.vitalbmx.com/community/ethan-bmx,18892/setup 25 131 2 20 8
5/3/2008 8:04 PM
90 then 180
-nice bike-
04wildman
5/3/2008 8:36 PM
Uh, if you do a forwards 180, you will be landing backwards. So it's obviously a good idea to learn how to ride backwards first... Duh. You don't have to be able to ride down a narrow path backwards or anything, just far enough to were you run out of momentum. A fakie is a backwards 180 and the easiest way to ride out of a forwards 180! Do the math, its better to now what to do after you land in a180 before you actually 180! If you add the two together what do you have? hmmmmm? A 360 thats a little under rotated but can still be rode out of smoothly because you were smart and have already been working on you FAKIES.
04wildman
5/3/2008 8:41 PM
spend as much time on manuals as you can fucking stand!
sundaybmxRR
Vital BMX member sundaybmxRR
8288 sundaybmxRR http://p.vitalbmx.com/photos/users/8288/avatar/c50_15102296_10210973470117928_1569641672_o_1479535352.jpg?1479534940 http://www.vitalbmx.com/community/sundaybmxRR,8288/all 07/13/07 233 223 114 http://www.vitalbmx.com/community/sundaybmxRR,8288/setup 334 10975 1227 20 662
5/3/2008 8:43 PM
listen to these words, i never learned how to manual good cause it didnt really interest me, so i can only manual maybe 30 feet if im lucky. hahaha
but my 2 friends who learned when they started out can manual almost a half mile, its crazy
just practice everything so you get the feel of them awhile so they seem easier in the future
IrIdEbMxDiDuKnOw
Vital BMX member IrIdEbMxDiDuKnOw
19153 IrIdEbMxDiDuKnOw http://p.vitalbmx.com/photos/users/19153/avatar/c50_629236988_1210417033.jpg?1293058401 http://www.vitalbmx.com/community/IrIdEbMxDiDuKnOw,19153/all 05/01/08 2 5 4 1 http://www.vitalbmx.com/community/IrIdEbMxDiDuKnOw,19153/setup 6 46 2 11 3 1
5/5/2008 12:37 AM
ur next best trik would hella be 2 go up ur fav q.p hop a lil b4 the coping so u do like a fakie disaster and hop again b4 u roll bakwards and turn ur bars swing the bak until u land 180 in the q.p
its the hardest thing to do(make a bmx part that will never brake) but if you got warranty throw it kick it bend it brake it but dont customize it warranty is there for a reason so u can get free things if it brakes
DaNokeBMX
Vital BMX member DaNokeBMX
17358 DaNokeBMX http://p.vitalbmx.com/photos/users/17358/avatar/c50_630689358_1216443960.jpg?1293054326 http://www.vitalbmx.com/community/DaNokeBMX,17358/all 03/24/08 65 3 2 46 1088 44 76
5/5/2008 4:30 AM
up the street from my house is this litttle hill
and i used to ride up the hill and lean back
thats how i learned fakies
i love to do them
although they are very easy
Bikes Make Me Jizz
Ep!cBMXer2theCore
Vital BMX member Ep!cBMXer2theCore
10974 Ep!cBMXer2theCore http://p.vitalbmx.com/photos/users/10974/avatar/c50_627184978_1222306557.jpg?1293040550 http://www.vitalbmx.com/community/Ep-cBMXer2theCore,10974/all 10/18/07 3 13 40 1 http://www.vitalbmx.com/community/Ep-cBMXer2theCore,10974/setup 9 53 3 95 3
5/21/2008 9:22 PM
Is it posible to do a bunnyhop X-up?
I'd agree with you, but then we'd both be wrong.
sundaybmxRR
5/21/2008 9:23 PM
yes
i know people who do them all the time
wittman
Vital BMX member wittman
16254 wittman http://p.vitalbmx.com/photos/users/16254/avatar/c50_629907488_1218876600.jpg?1293051919 http://www.vitalbmx.com/community/wittman,16254/all 02/25/08 25 4 http://www.vitalbmx.com/community/wittman,16254/setup 6 395 123 2
5/21/2008 9:33 PM
learn ur manuals, later on theyll b useful and try a 180 by bunnyhopin, dont need to get as high as u can, theres time fo that later on
sja_ridebmx
Vital BMX member sja_ridebmx
19866 sja_ridebmx http://p.vitalbmx.com/photos/users/19866/avatar/c50_114183400_1235546560.jpg?1293059976 http://www.vitalbmx.com/community/sja-ridebmx,19866/all 05/12/08 17 7 http://www.vitalbmx.com/community/sja-ridebmx,19866/setup 7 73 21 17
5/22/2008 3:26 AM
just try whips or bakflips or 1080s. na just try 180s. just carve like fuk wen u do it
2wheelsisalluneed
Vital BMX member 2wheelsisalluneed
16195 2wheelsisalluneed http://p.vitalbmx.com/photos/users/16195/avatar/c50_106233220_1236158275.jpg?1293051776 http://www.vitalbmx.com/community/2wheelsisalluneed,16195/all 02/24/08 1 48 20 62 411 1 99 1 24
5/22/2008 3:32 AM
start learning how to spin out of a quarter and then when you try to hop and spin first get to 90 degrees andthen 180(focus more on the spin than the hop).
