Does my headset look on right?
Evan1177
Vital BMX member Evan1177
112147 Evan1177 /images/default/avatar/c50.png http://www.vitalbmx.com/community/Evan1177,112147/all 07/04/14 http://www.vitalbmx.com/community/Evan1177,112147/setup 4 2 1 1
7/4/2014 3:27 PM
Everything works great and it spins as fast as always but is there suppose to be this gap like this?
I put it down as far as I could.
crispy_nugget
Vital BMX member crispy_nugget
88866 crispy_nugget http://p.vitalbmx.com/photos/users/88866/avatar/c50_971616_588060891216285_825454669_n_1378378215.jpg?1378377636 http://www.vitalbmx.com/community/crispy-nugget,88866/all 12/29/11 http://www.vitalbmx.com/community/crispy-nugget,88866/setup 8 49 1
7/7/2014 1:15 PM
Mine looks like that and works fine its a wtp headset with a pro-lite cap
BORN FAST ish
crispy_nugget
7/7/2014 1:16 PM
unless you mean your stem that looks wrong
BORN FAST ish
boston
Vital BMX member boston
107033 boston http://p.vitalbmx.com/photos/users/107033/avatar/c50_image_1406444695.jpg?1406444253 http://www.vitalbmx.com/community/boston,107033/all 07/18/13 http://www.vitalbmx.com/community/boston,107033/setup 13 445 4 3
7/13/2014 8:44 PM
Running the stem like that is gonna be a bad time.
I'd pull that spacer. Maybe use one half that large or the stem is gonna let go brutally just going off a curb!
adfkje
Vital BMX member adfkje
111978 adfkje http://p.vitalbmx.com/photos/users/111978/avatar/c50_53ce5bf03b73b_1417316861.jpg?1417316424 http://www.vitalbmx.com/community/adfkje,111978/all 06/17/14 1 84 325 2 2
7/28/2014 7:57 PM
it's 'right' with regards to your spacer alignment, if that's what you mean (ie, the gap between the top of your head-tube and the 'race' thing [lol dunno what they're called])...
if you mean the entirety of it, then hell no, your stem is wayyy high on your fork's steerer tube, i mean scary high and i'd def second Boston in that the thing doesn't even look safe (just look at your 1st pic: your fork's steerer tube is only about halfway into that stem. If you want that to be safe, you need a new fork w/ a longer steerer tube, or, much more practical, just ditch that spacer so you can put the stem down further on your steerer tube. W/o putting my ruler to my screen, it does look like removing that spacer will be more than sufficient to give you all the stem:steerer contact needed... hell, it may be too much and require you to either chop the steerer tube further, or use a smaller spacer than the one you have there right now. Either way plz don't ride that, even gently/carefully, cuz just 'not breaking it' isn't useful I know i'd be uncomfortable knowing my stem was stressed like that being only half-connected and then force being applied, even just a cruise-ride's amount of force)
sketchytravis
Vital BMX member sketchytravis
70594 sketchytravis http://p.vitalbmx.com/photos/users/70594/avatar/c50_132498910_1288141411.jpg?1293152590 http://www.vitalbmx.com/community/sketchytravis,70594/all 10/26/10 7 http://www.vitalbmx.com/community/sketchytravis,70594/setup 84 4919 8 9 3
7/29/2014 12:00 AM
ehh youre probably good.
skooter... dont be a pussy
adfkje
7/30/2014 4:02 PM
you're wrong. Not only is it dumb to have only half the strength of contact your stem/steer-tube are designed to have, but when it's hanging half off the top like that the stress isn't evenly distributed to the stem.
michael.eckhart
Vital BMX member michael.eckhart
94768 michael.eckhart http://p.vitalbmx.com/photos/users/94768/avatar/c50_282496_2204891932617_8330429_n_1399090862.jpg?1399090143 http://www.vitalbmx.com/community/michael-eckhart,94768/all 06/03/12 24 http://www.vitalbmx.com/community/michael-eckhart,94768/setup 31 505 9 6
9/2/2014 10:31 PM
take that spacer out and slam that shit down and increase your clamping surface. The top of your fork should be in the upper clamping area of your stem, otherwise your are going to end snapping the stem or breaking your fork bolt out. As for your Top head set cap, some just have that gap, as long as there is no wiggle and your bars still spin, you should be fine. Also just a tip, dont buy parts with stupid cutouts, your are sacrificing saftey for weight that does not matter.
isnowyaznV2
Vital BMX member isnowyaznV2
95706 isnowyaznV2 http://p.vitalbmx.com/photos/users/95706/avatar/c50_360_out_of_the_bank_Wackford_1449123362.jpg?1449122596 http://www.vitalbmx.com/community/isnowyaznV2,95706/all 06/29/12 11 http://www.vitalbmx.com/community/isnowyaznV2,95706/setup 183 4705 29 30 5
9/2/2014 10:44 PM
Holy hell, take off that spacer, lol. Your fork steerer tube should always be right on top of any hollow places in the stem. As for the headset dust cover, there's always supposed to be a gap, or else it would rub on the headtube cup. The gap should never be too big though.
