SIRE
I've been trying to learn bunnyhop 3s on flat for a while now, and not being able to do them is starting to frustrate me. I can usually get the full 360 degrees of rotation but not before my back wheel touches the ground. I usually get between 180 and 270 then my back wheel hits. I've watched a few YouTube videos where people say to suck your back end up, but I don't really know how to do that. I'm not sure what to do with my body to get the back higher. I've pretty much only tried them on flat with a few attempts on a ramp at a skatepark. I'm not sure if I should try to learn them off a ramp/bank first or on flat. Any help about avoiding tire taps or anything else would be greatly appreciated. Thanks!
Refs: element4all, kroller
Limitrider5
What they mean by sucking up is to bend your knees. But I learned them on a pyramid and I got them dialed in a day flat
rame:20" Top Tube, Integrated headtube with removable Gyro Tabs, Mid BB, 14mm Axle slot, Welded on brake mounts, and an integrated seat clamp
Fork:4130 CrMo Steerer Tube, 10mm Axle
SlotsChainset:Tubular CrMo 175mm
Chainrings:25 Tooth Fit DL style Sprocket
Bottom Bracket
ealed Mid
Bottom BracketCassette:9 Tooth Sealed Bearing Driver
Chain:KMC Z410 Pink
Pedals
tolen Thermalite Sp
Inch Rise, 27 Inch
WideStem:Front Load
AlloyHeadset:Campy Compatible 45 x 45 Integrated
Grips:Fit OG
Rims:Alienation PBR 36h
Front Hub:10mm AxleRear
Hub:14mm Sealed Cassette Hub, 9t Driver
Spokes:14g BlackFront
Tyre:Fit 20'' x 2.10''Rear Tyre:Fit 20'' x 2.10''
Saddle:Fit Embossed
Seatpost:25.4mmSeat
Binder:Integrated
Weight:25.75 lbs
CharlieWalsh
mine arent perfect but if you tuck your knees up as if your trying to do a high hop and it usually comes round. also, tucking forward towards the bars moves your (centre of gravity? axis?) forward and speeds up the rotation.
SIRE
CharlieWalsh wrote: mine arent perfect but if you tuck your knees up as if your trying to do a high hop and it usually comes round. also, tucking forward towards the bars moves your (centre of gravity? axis?) forward and speeds up the rotation.
When I pull my knees up to my butt should I extend my arms out to compensate or not?
Garett_Kanters
keep your head turned and spot your landing
I ride a: Cult
why do I ride?:peer pressure
Rhueisgooey
everyones threes are different in the way they do them, what i do is i lean over my bars a lot and the more forward i lean before i do the three the higher i can tuck in the back wheel.....thats atleast how i do them
ThomasEller
If you havent gotten them yet, this is what I did. I first learned them to fakies on a hill, then I took them to a jump. I just decided to try them flat one day and I got them pretty quickly. They are easier than you think.
Refs: FreddyDapice, Skids007, siege eh
