HOW TO FIX YOUR BIKE
ridebmxnc
Vital BMX member ridebmxnc
28546 ridebmxnc http://p.vitalbmx.com/photos/users/28546/avatar/c50_6054_1129360799731_1398540474_30532419_2687458_n.jpg?1301579380 http://www.vitalbmx.com/community/ridebmxnc,28546/all 08/30/08 104 21 http://www.vitalbmx.com/community/ridebmxnc,28546/setup 363 6445 258 1 11
12/2/2009 4:46 PM
Edited Date/Time: 4/14/2016 11:16 PM
Wheel building and wheel truing
Wheel building
I have no experienced in this so I am going to refer you to some videos and web sites that can explain it better then I ever could.
Wheel building videos
Part 1
Part 2
Wheel building web sites
These are for you less visual learners that like to read more then watch.
http://www.tenpackbmx.com/...eel_Building_101.pdf
http://sheldonbrown.com/wheelbuild.html
An amendment to the section twisted added on wheel building...
what to do after your wheel is built... by ridebmxnc
Once you've built your wheel and your spokes are all properly tensioned (barely move when you squeeze two of them together if at all), your going to want to break in your newly built wheel.
Just like you have to break in a new pair of shoes, a wheel needs to be broken in before its riden too hard or your going to create a lot more work for yourself. Why you ask? Because spokes are typically much harder than the material your hub is made out of and when you put stress on two metal parts rubbing together one of them is going to have to give. If you've ever taken apart a hub before you'll notice that some if not all of the spoke holes on your hub will have a little indentation around the hole. That is where the spoke has pulled on the flange and set itself during its initial break in period.
So what are you supposed to do with this knowledge now? Pre-stress your wheel before you go really ride it for the first time. Now getting back to what next from the first paragraph...
First thing after youve built your wheel, go and find a block of wood. Set one side of your axle on it and press down on the rim, do it gently at first but enough to make the wheel flex a little. Rotate it around and then flip it upside down and do the same thing on the other side.
Next, go back and re-tension and true your wheel because this will have started some of the break in process and the spoke heads will have set a bit.
Next go back to your piece of wood and do the same thing except this time your going to stand on your wheel instead.
Now go back in and re tension and true your wheel again.
Now your wheel is ready to start riding, but not anything hard. Try taking it around the block a few times and doing some bunny hops or 180s.
Go back inside and re-tension and true your wheel. Do this a couple more times and your wheel should be about broken in and ready to do some real riding. After every session your first couple of sessions make sure you re-check the tension and true again.
Performing this process will greatly improve the stiffness and life of your wheelset. Note be very careful stressing the wheel by standing on it... if you're a big dude it might be a better idea to find a smaller person to do it for you just to be safe.
Truing
In short to true all you do is loosen and tighten spokes. Finding out which spokes you tighten and loosen and by how much is the tricky part. Truing is a very time consuming process, which the more times you do it the easier it will become. No matter which method you use you will do the same thing to true you wheel.
First you will find out to which side the wheel is wobbling too. If the wheel wobbles to the left you tighten the spokes on the right then if need be you also loosen spokes on the left just slightly and vice versa. You will only want to turn the spoke about a half turn each time because the spoke could twist and you don’t want that. TAKE YOUR TIME.
Normally you would want and truing stand to do this but there are other ways. Some common ways to check to see if you wheel is true is to use your brakes as guides. We all know most of us don’t run brakes anymore so what else can we use? I will try to explain some of the other things we can use and how to use them. You can use zip ties, markers and you can even build your own truing stand.
Zip ties
Okay, for this you will want to get some zip ties. They will act as you indicator and help you figure to which side the wheel wobbles. You will just put them on your forks so the end is near the wheel.
Marker
1. Get a marker
2. Spin the wheel
3. Slowly move the marker towards the wheel using the forks as a brace.
4. As soon as it touches the wheel you remove it.
5. It should leave a nice mark where you wheel is out of true.
6. Find the mark and tighten the spoke on the other side of the wheel and loosen the spokes on the marked side of the wheel.
7. Repeat on both sides of the until it’s completely true
Home made truing stands.
For the people that want something a little permanent then Zip Ties but don’t want to spend a bunch of money on a truing stand.
Forks and a vice
What you will need
1. Vice
2. Zip ties or anything else that you want to use as the indicator
3. Old forks
I could tell you how to build it but it would be easier to just show you a picture
Here is a link to another one.
http://www.instructables.com/id/S8T2I8KFCEIJ24L/
Please message me if you think if something should be changed or added to it.
HOW TO PUT YOUR BIKE TOGETHER
BMX riding Cop... Let that sink in for a minute.
alexnjbmx
Vital BMX member alexnjbmx
38280 alexnjbmx http://p.vitalbmx.com/photos/users/38280/avatar/c50_88865240_1261859366.jpg?1293084749 http://www.vitalbmx.com/community/alexnjbmx,38280/all 01/06/09 25 19 http://www.vitalbmx.com/community/alexnjbmx,38280/setup 62 8291 7 2
12/2/2009 4:47 PM
wooot. add some more things to this and then sticky it so we can help people fix their bikes!
I LOVE FLY BIKES
I'm what Willis was talking 'bout
member of the week 2/22/10 - 2/28/10
Twisted654
Vital BMX member Twisted654
44806 Twisted654 http://p.vitalbmx.com/photos/users/44806/avatar/c50_94363740_1276299159.jpg.jpg?1293100886 http://www.vitalbmx.com/community/Twisted654,44806/all 05/26/09 48 6 95 9415 7 7
12/2/2009 4:48 PM
Edited Date/Time: 12/2/2009 5:43 PM
I posted my truing tut on a separate thread but I am having trouble finding it. As soon As I find ill add it back?
edit: found it do you want to edit so it fits better or shall I just paste it in?
http://www.vitalbmx.com/forums/General-BMX-Talk,2/Wheel-building-and-wheel-truing,564297
JustRideBMX
Vital BMX member JustRideBMX
26925 JustRideBMX http://p.vitalbmx.com/photos/users/26925/avatar/c50_Untitled.jpg?1362014796 http://www.vitalbmx.com/community/JustRideBMX,26925/all 08/10/08 198 http://www.vitalbmx.com/community/JustRideBMX,26925/setup 548 25305 581 1 49
12/3/2009 4:33 AM
Very good idea, but NOBODY is gonna look at this. You know how the noobs are.
My nigga Ressler, stay up!
My nigga Babysatan, stay up!
My nigga Copiolet, stay up!
My nigga DakAttack, stay up!
My nigga NCDave, stay up!
My nigga Enzo, stay up!
And I ride for my niggas
Twisted654
12/3/2009 4:50 AM
The old one got up to 7 pages then he cleaned it up and it got back up to 5 pages. We just have to get all the info back up there.
Liam163
Vital BMX member Liam163
46754 Liam163 http://p.vitalbmx.com/photos/users/46754/avatar/c50_86917930_1265056791.jpg?1293104119 http://www.vitalbmx.com/community/Liam163,46754/all 06/27/09 1 27 1 139 2966 1 4
12/3/2009 8:30 AM
You should times in for the How To Build a Bike series that tells you what section is at what time.
Such as: Part 1 - 3:45-4:50 - Forks
(not actual timing, just an example)
"Oh You Mad Cuz I'm Stylin On You?"
Tommyboy
Vital BMX member Tommyboy
42469 Tommyboy http://p.vitalbmx.com/photos/users/42469/avatar/c50_Photo0415.jpg?1310719349 http://www.vitalbmx.com/community/Tommyboy,42469/all 04/04/09 14 1 http://www.vitalbmx.com/community/Tommyboy,42469/setup 86 1879 35 1
12/3/2009 4:27 PM
what crank puller works from demo medial 2.0 (48 spline, 19mm)?
Burn Lexington
Scarlett O'Hara
BIKE CHECK!
SECOND BIKE CHECK!
REFs....
blake el gingero, bsticks, bmx24, irideafly(x2), bigbarsbeard, hcpmicheal(x2), carjakester, 3514eclat, iridebikes07, throwafit, lee_rager, bwenger, aw1234512, kwescottbmx, ecuadevil, ScramHype, dakiddjai93, Spikes5(x3), ultrablade, BEASTASSDICK(x2)
ridebmxnc
12/3/2009 5:36 PM
the same one as the profile one
Tommyboy
12/3/2009 6:03 PM
do you know if part tools makes one that works?
Burn Lexington
Scarlett O'Hara
BIKE CHECK!
SECOND BIKE CHECK!
REFs....
alexnjbmx
12/4/2009 4:15 AM
thye do, but just buy the profile one off of danscomp
I LOVE FLY BIKES
Tommyboy
12/4/2009 6:35 AM
alright, thanks
Burn Lexington
Scarlett O'Hara
BIKE CHECK!
SECOND BIKE CHECK!
REFs....
alexnjbmx
12/4/2009 12:11 PM
Tommyboy wrote:
alright, thanks
no problem homes
I LOVE FLY BIKES
squash96
Vital BMX member squash96
39652 squash96 http://p.vitalbmx.com/photos/users/39652/avatar/c50_dbl_peg.jpg?1299675776 http://www.vitalbmx.com/community/squash96,39652/all 02/04/09 12 8 1 119 1642 8 1
12/5/2009 5:50 AM
those lacing vids could come in handy for me
http://www.facebook.com/profile.php?ref=name&id=100000120996960
""""\___/""""
does this make my signature look fat?
Jarred {F.R.} (F.F.C.)
Vital BMX member Jarred {F.R.} (F.F.C.)
53827 Jarred {F.R.} (F.F.C.) http://p.vitalbmx.com/photos/users/53827/avatar/c50_86705020_1259931947.jpg?1293118275 http://www.vitalbmx.com/community/Jarred-F-R-F-F-C,53827/all 11/17/09 28 http://www.vitalbmx.com/community/Jarred-F-R-F-F-C,53827/setup 6 112 2
12/5/2009 8:02 AM
why would you even need a crank puller? thats the same useless tool as a pedal wrench
WE RIDE SUNDAYS BITCH
ridebmxnc
12/5/2009 9:08 AM
Because you don't want to beat on your crank arms with a hammer...
A. It voids the warranty
B. You can dent your cranks and scratch the hell out of them.
C. That's how they're designed to be taken apart.
And on almost all road and mtbs you have to have a crank puller to take cranks off. Not the same style as bmx 48 spline crank removers but there's a reason they created the tool so you should be using it.
alexnjbmx
2/14/2010 8:16 AM
exactly. crank pullers should be a tool that everyone should have.especially if you have a 48 spline crank system. if you have cranks with a pinch bolt, you dont need the crank puller as much or at all
I LOVE FLY BIKES
ridebmxnc
2/14/2010 4:05 PM
Edited Date/Time: 2/14/2010 4:08 PM
i added an update to the wheel building section
alexnjbmx
2/14/2010 6:25 PM
very good addition
I LOVE FLY BIKES
sikracing17
Vital BMX member sikracing17
64572 sikracing17 http://p.vitalbmx.com/photos/users/64572/avatar/c50_IMAG0833.jpg?1328575624 http://www.vitalbmx.com/community/sikracing17,64572/all 07/11/10 2 14 http://www.vitalbmx.com/community/sikracing17,64572/setup 3 5 6
7/12/2010 9:29 PM
yah those were good vids i'd like to see more to
sikracing17
7/12/2010 9:31 PM
i'd like to add a request on putting pettles on because when i put them in they cross thread, and i would also like to do it myself instead of my friend
alexnjbmx
7/22/2010 8:07 AM
no.
especially since you cant spell pedals correctly
I LOVE FLY BIKES
carryongrinding
Vital BMX member carryongrinding
73472 carryongrinding http://p.vitalbmx.com/photos/users/73472/avatar/c50_130funny.jpg?1320646913 http://www.vitalbmx.com/community/carryongrinding,73472/all 12/27/10 2 http://www.vitalbmx.com/community/carryongrinding,73472/setup 58 138 2 63 2 3
12/28/2010 9:56 AM
GET SOMEONE ELSE TO DO IT
GT BMX forever fuck you haters!
cooljon
Vital BMX member cooljon
48206 cooljon http://p.vitalbmx.com/photos/users/48206/avatar/c50_PC160001.jpg?1297124471 http://www.vitalbmx.com/community/cooljon,48206/all 07/26/09 3 2 5 24 6 2
4/2/2011 4:09 PM
does anyone know how to change bearings on a front hub?
Sadie
Vital BMX member Sadie
83583 Sadie http://p.vitalbmx.com/photos/users/83583/avatar/c50_1_1248497_6282_t.jpg?1313260808 http://www.vitalbmx.com/community/Sadie,83583/all 08/13/11 1 2
8/13/2011 11:48 AM
Does anyone know how to fix sqeaky brakes?
zacsmyser
Vital BMX member zacsmyser
83581 zacsmyser http://p.vitalbmx.com/photos/users/83581/avatar/c50_dirt_hits.jpg?1313280971 http://www.vitalbmx.com/community/zacsmyser,83581/all 08/13/11 4 2 11 1 1
8/15/2011 1:03 PM
Tommyboy wrote:
alright, thanks
alexnjbmx wrote:
no problem homes
what fly parts do you have? i just got the new tierra 4 and im looking at their rims and hubs.. know if their any good?
keep on riding
NOGOODNAME
Vital BMX member NOGOODNAME
83241 NOGOODNAME http://p.vitalbmx.com/photos/users/83241/avatar/c50_xuuM5yHh_1370565473.jpg?1370564828 http://www.vitalbmx.com/community/NOGOODNAME,83241/all 08/04/11 2 18 310 16 5 4
8/20/2011 4:36 PM
Boldly going nowhere.
BIKE CHECK.
Tim_Heaney
Vital BMX member Tim_Heaney
85769 Tim_Heaney http://p.vitalbmx.com/photos/users/85769/avatar/c50_fb_picture_1714111795.jpg?1318137270 http://www.vitalbmx.com/community/Tim-Heaney,85769/all 10/08/11 1 1
10/8/2011 10:40 PM
NOGOODNAME wrote:
Set your brake pads at a slight angle so that the front edge hits the rim before the back edge. (just slightly) that should fix your problem and not effect your stop ability.
angel.marco99
Vital BMX member angel.marco99
81050 angel.marco99 http://p.vitalbmx.com/photos/users/81050/avatar/c50_fb_picture_1474185460.jpg?1308497873 http://www.vitalbmx.com/community/angel-marco99,81050/all 06/19/11 5 1
3/1/2012 10:25 AM
hello, im a starter in bmx and i would like to buy a new stem for my bike which is a 2011 wethepeople arcade completely stock, the current stem is a Salt alloy front loading, my fork is a Hi-ten steel fork, 1pc bulged cromo steerer and the Handlebar 1020 Hi-Ten steel, 7.75 inch and i would like to buy the shadow conspiracy strike TL stem and i dont knowif it will fit and how to meassure it. If the shadow conspiracy stem doesnt fit could you please recomend me other good and if possible yellow stems that would fit
thak you for your time
Marty_TheRussian
Vital BMX member Marty_TheRussian
89745 Marty_TheRussian http://p.vitalbmx.com/photos/users/89745/avatar/c50_fluttershy_is_not_amused_by_stinkehund_d3fw22x.jpg?1338823497 http://www.vitalbmx.com/community/Marty-TheRussian,89745/all 01/22/12 http://www.vitalbmx.com/community/Marty-TheRussian,89745/setup 6 73 7 2
3/20/2012 6:12 PM
send your bike my way along with 50 bucks and ill make it dialed as fuck!
~O-ville Biker~
I ride Eastern, Get over it!
Marty_TheRussian
3/20/2012 6:14 PM
measure the stack height. or just buy some spacers to be safe
~O-ville Biker~
