Need help with crappy cassette hub
David_Pete
Vital BMX member David_Pete
112026 David_Pete /images/default/avatar/c50.png http://www.vitalbmx.com/community/David-Pete,112026/all 06/22/14 1 1
6/22/2014 9:19 PM
Alright so i got this rim that came stock on some of the older kinks like the launch, its a pbr with a mission function unsealed cassette hub. This rim was takn apart and all the bearings got put into a coffee can full of bearings and iv tried so many different combinations to get this rim to work but it will not work. When I put it on the bike after rebuilding it jus pops and creeks like crazy, does anyone know what size ball bearings go in which cup? Casette works fine btw PLease help I want to ride so f**king bad and this rim is the only thing stopping me!
isnowyaznV2
Vital BMX member isnowyaznV2
95706 isnowyaznV2 http://p.vitalbmx.com/photos/users/95706/avatar/c50_360_out_of_the_bank_Wackford_1449123362.jpg?1449122596 http://www.vitalbmx.com/community/isnowyaznV2,95706/all 06/29/12 11 http://www.vitalbmx.com/community/isnowyaznV2,95706/setup 183 4704 29 30 5
6/23/2014 10:33 PM
Edited Date/Time: 6/23/2014 10:33 PM
First mistake was mixing ball bearings.. But honestly, smaller ball bearings usually go on the inner side of the unsealed drivers. Save up for a sealed hub, at least semi-sealed. And use as much grease as possible with these, except on the pawls. And tighten the cones just enough.
David_Pete
6/26/2014 10:21 AM
Small bearings on driver side, a TON of grease and she works like a dream Thanks!
