Trying to raw my bike...
Maddvillain
Vital BMX member Maddvillain
111813 Maddvillain /images/default/avatar/c50.png http://www.vitalbmx.com/community/Maddvillain,111813/all 06/01/14 1 1
6/1/2014 11:52 AM
Edited Date/Time: 6/1/2014 12:03 PM
So I'm giving my bike a facelift.
Getting some new parts (just bars and soft parts) and I wanna raw all the gold/bronze spray painted stuff with stock paint underneath and get the front fly rim back to stock black without de lacing. So I have 3 questions:
What's the best stripper or other stuff I can use?
Can I just use stripper and a wire brush or will I need to rent a pneumatic wire wheel?
And will the front wheel definitely have to be unlaced to make it look acceptable?
I might just get black spray paint instead of clear coat so it doesn't have to be stripped perfectly, at least the front wheel, it's trued perfectly and I don't want to take it apart again.
I Need suggestions, I've never rawwed a bike.
Thanks guys.
Maddvillain
6/1/2014 11:56 AM
Grimy
dirtydog
Vital BMX member dirtydog
112102 dirtydog http://p.vitalbmx.com/photos/users/112102/avatar/c50_20140703_211003_zps15b244f1_1404446479.jpg?1404446256 http://www.vitalbmx.com/community/dirtydog,112102/all 06/30/14 2 61 1
7/4/2014 5:11 PM
Edited Date/Time: 7/4/2014 5:14 PM
Did you do this yet?
If not....
First of all, you need to get that bike stripped down of all the components. You def can't do the work with it like that.
I would use Brass wire wheel. It will do a good job and not scratch the metal like the metal wire wheels will since they are extremely coarse. Brass is much gentler.
Do you know anyone with a sandblaster? Would be a heck of a lot easier...
As for the wheel. I would try scothbrite pads first. I think red is coarse, green is medium. You could scuff it up with the scotch brite and then just paint right over in black.
sweetbmxdude
Vital BMX member sweetbmxdude
112171 sweetbmxdude http://p.vitalbmx.com/photos/users/112171/avatar/c50_fallout_1405957835.jpg?1405957721 http://www.vitalbmx.com/community/sweetbmxdude,112171/all 07/07/14 3 http://www.vitalbmx.com/community/sweetbmxdude,112171/setup 5 56 1
7/7/2014 1:00 PM
strip that bitch immediately, its an abomination. anyways use some good ole aircraft stripper, or anything hardcore. wear gloves, spray it or spread it all over all your parts that you want stripped. wait 20-30 minutes, and wash all the stripper off, the paint should wash off with it.
I love sketchy shit
this is my ride
Team Hazard for life.
Brayden_Buckingham
Vital BMX member Brayden_Buckingham
82424 Brayden_Buckingham http://p.vitalbmx.com/photos/users/82424/avatar/c50_image_1465865153.jpg?1465864271 http://www.vitalbmx.com/community/Brayden-Buckingham,82424/all 07/17/11 13 http://www.vitalbmx.com/community/Brayden-Buckingham,82424/setup 432 6142 267 10 7
7/10/2014 1:54 PM
Oven cleaner that bitch
My S&M Bonesaw
My most recent edit : https://youtu.be/Pcbj3CuFv0g
"Pop a hard 180 into the dirt !" - Cam Swift
Doesn't matter if they ride scooters or rollerblades , we all just want to have fun
ghostx720
Vital BMX member ghostx720
112229 ghostx720 http://p.vitalbmx.com/photos/users/112229/avatar/c50_badger_1405749659.jpg?1405749376 http://www.vitalbmx.com/community/ghostx720,112229/all 07/11/14 9 150
7/13/2014 10:17 AM
A can of Aircraft stripper and some GLOVES are a must for this! I LOVE bmx paint jobs and shit.
MAKE SURE YOU REMOVE ALL COMPONENTS PRIOR TO USING AIRCRAFT STRIPPER, let the stripper soak into the paint on the frame and start scrubbing everything off with a hard sponge after about 7-10 minutes.
You may have to attack trouble spots like in between frame welds and what not by repspraying those trouble spots and letting them soak a little more.
Personally, I would use NOTHING else but aircraft stripper because its mad powerful and removing paint and does it QUICK. follow it up with a wipe down using a rag and some isopropyl alcohol or acetone to remove any particulate on the surface of the frame being painted/stripped for a quick and painless cleaning process. Good luck m8
ghostx720
7/13/2014 10:19 AM
didnt realize how old this thread was. Hopefully OP has done it already and is the bike is riding now its been about a month lol if not OP you got some more good advice.
