Frame: Phero FULL 4130 chromoly frame with butted down tube. Replaceable brake mounts and cable stop. Internal headset, Spanish BB and holes for gyro tabs.
Fork: GUERRA, FULL 4130 chromoly with 1pc CNC steerer tube. Machined integrated bearing race and tapered legs
Headset: Sealed bearing 45/45 integrated
Chainwheel: EZRA "Equis" 25t Alloy sprocket CNC machined from 7075 Billet Aluminum
Crank: ODYSSEY Twombolt Cranks, 175mm
Bottom Bracket: Sealed bearing Spanish
Handlebar: GUERRA "Toro" Bars, 13-butted Chromoly bars, 8.25" x 28"
Stem: EZRA "Guantlet", CNC machined from Billet 7075 Aluminum with Hardended Chromoly Bolts
Grip: Odyssey Chase Hawk grip
Front Hub: EZRA hub 7075-T6 alloy axle, heat-treated chromoly studs.
Rear Hub: G-SPORT Ratchet hub, Left or Right hand drive 9t Cassette hub
Front Rim: ALIENATION SKYLARK double wall alloy rim, 36 Hole
Rear Rim: ALIENATION RUNAWAY double wall alloy rim, 36 Hole
Spokes: 14G Stainless w/ Brass Nipples
Front Tire: ODYSSEY Aaron Ross 20x2.35, 100psi
Rear Tire: intense micro 20x2.25 90psi
Cable: Straight cable
Rear Brake: Odyssey EVO -II
Brake Lever: Amber [RUSH] 6061 Forged with Hinged Clamp
Chain: shadow conspiracy Half-link chain
Saddle: AMBER Pivotal
Seat Post: Forged alloy pivotal
Seat Clamp: Guerra Internal clamp
Pedals: ODYSSEY Twisted PC pedals
Velcro Cable Strap, 2 Pegs
Top Tube Length (inches): 21
i will never die, my world will only end...[[[REFS,,, showtime402, _brendan
