Been searching everywhere since this came out. Finally found one and ordered it up.
The only thing in going to do from here on out, maybe a silver half link chain, colony oil slick wasp hubs, and an extra set of tires.
SPECS
Top Tube Length 20.65 in
Frame Geometry HT: 75° / CS: 13.25 in / BB: 11.8 in / SO: 9 in / ST: 71°
Frame Info 100% 4130 cromo tubing with removable brake mounts and guides, integrated head tube, mid bb, embossed logo top and downtube gussets
Forks 100% 4130 cromo with cnc steerer, integrated bearing race, tapered legs with angled ends and cnc dropout holes
Handlebars 8.85 in rise, 28.5 in wide, 10° back sweep, 2° up sweep, 100% 4130 cromo
Grips United flangeless grips, United nylon ends
Headset United sealed bearing integrated
Stem Colony top load (oil slick)
Lever Alloy (not pictured)
Brake 990 (not pictured)
Cranks 3pc 175mm, tubular cromo, 19mm 8 spline spindle, stamped United logo
BB United sealed bearing mid, 19mm
Sprocket Colony CC 25t (oil slick)
Pedals United Valentino Nylon
Chain United Supreme X410
Rear Rim Alloy 36h, double wall
Front Rim Alloy 36h, double wall
Rear Hub 36h United Supreme sealed alloy cassette, 14mm axle, sealed bearing 9t driver, 4 pawl, ultra load mech
Front Hub 36h United Supreme alloy, sealed bearing, 10mm female axle
Rear Tyre United Direct 20 x 2.4
Front Tyre United Direct 20 x 2.4
Seat Shadow Conspiracy Kobza pivotal
Seat Post United alloy pivotal
Seat Clamp Alloy
Pegs 4 x steel 100mm (not pictured)
Weight 24 lbs / 10.88 kg
Extras not pictured on bike
-Kink rear hub guard
-Shadow conspiracy sprocket guard
- 4 pegs
