Ke Kee's debut.
1/24/2015 1:37 PM
This is Ke Kee (key key) my daily driver.
Frame : 2015 kink curb
Forks: kink volte 2
Bars : kink linx
Stem : mission front load
Headset : mission headset
Grips: cult vans gum
Barends : cult
Lever : none
Cranks :mission triumph
Pedals: mission plastics
Sprocket : mission cipher 25th
Chain : mission full link chain
Brakes : none
Pads :none
Seat : mission seat post combo
Seatclamp : mission clamp
Rear Wheel : mission x7
Front Wheel : mission x7
Tyres : odyssey Aaron Ross keyboard
I've had this bike for about a week and so far I love it. The only thing I don't like about it is the mission headset slips a lot no matter how much I tighten it so I will probley be changing it soon. Other than that this bike is solid and its a very affordable bike.
1/24/2015 1:44 PM
if it keeps ya riding. And the stem is slipping, not the headset
1/24/2015 4:58 PM
Yea you're right tomdon my bad I had a brain fart earlier. Lol.
1/26/2015 4:47 PM
Looks clean simplicity is nice sometimes
1/26/2015 5:17 PM
Forget to move your bars back after you landed nose-heavy or what
1/26/2015 5:47 PM
He said it slips alot.
1/26/2015 6:53 PM
yea my stem was slipping a lot at first and I got tired of moving my bars and I didn't wanna smash them on the ground so I just rode like that till I got home. The slipping has stopped now. I took some sand paper the bars and stem.
1/26/2015 7:08 PM
Edited Date/Time: 1/26/2015 7:13 PM
Id grab a sealed bb conversion kit while your looking at stems man...
or a tip... go to a hardware store, and find nylon washers(you can use steel ones, aluminum would be better, with a 19mm inner diameter, or 20 whatever, and put just enough in their so that your crank arm compresses them against the nut, this'll keep your bottom bracket from getting loose and also act as a shield for the spindle threads, ive used a headset spacer to do this before.
other then that, looks good. i like your seat post height wink
"The D.O.P.S. System"
DK, Odyssey, Profile, Shadow.
check out my bike check
@ethanbrackett
