Loud noise when pedaling hard and when I pedal backwards
2/23/2017 4:59 PM
Title pretty much explains it. I've tried everything to fix it. Tightened chain, loosened it, greased/cleaned chain. I just don't know what it is. If anyone could help that'd be great.
2/23/2017 6:08 PM
Wrong section... could a mod move this?
2/23/2017 6:43 PM
Check hub and bb bearings, make sure the bb spacer is installed and is the correct size if you haven't already. Make sure all metal on metal contact are greased. Check driver teeth/pawl and bearings. Check chain alignment.
