My First Bike Check
8/6/2011 5:36 PM
Its a video cause i only had a video camera
&feature=channel_video_title
everything is stock so here is the part list
Frame 20.5" tt, hi-tensile steel with a CrMo toptube, integrated headtube, mid bb, 14mm axle, removable brake mounts
Fork 4130 CrMo Tapered legs
Handlebar 4130 CrMo 7.75" X 26"
Stem Front load alloy
Grips Fit Inman
Bar Ends Fit bar plugs
Headset Campy 45°/45° sealed
Cranks 3 piece tubular CrMo 170mm
Sprocket Fit TRI 25T
Bottom Bracket Mid sealed bearing
Pedals Odyssey Twisted PC
Chain KMC 410H
Driver/Freewheel 9t
Front Rim Double Wall 36h
Rear Rim Double Wall 36h
Front Hub Sealed bearing 3/8 axle
Rear Hub Sealed bearing cassette 14mm axle
Front Tire Fit 2.25
Rear Tire Fit 2.25
Spokes 14g black
Seat Fit Embossed, 8mm rails
Seatpost Micro adjust
Seatpost Clamp Odyssey Mr. Clampy
Brakes Tektro U-brake
Brake Levers Tektro alloy
Cable Odyssey Linear
