My SE Custom bike check!
4/12/2017 10:08 AM
DESCRIPTION
double-butted main frame, 20" Alex DM 24 Double wall rims, 2.2" Maxxis DTH Folding tires, Odyssey Twisted PC pedals.
FEATURES
100% Cr-Mo, heat treated double-butted main frame, integrated head tube, machined mid bottom bracket, micro dropouts, removable cable guides & brake mounts.
* Full Cr-Mo heat treated tapered leg SE forks w/ cut-out clearance for pegs.
* SE seat w/ lightweight nylon Pivotal .
* SE 3pc closed end Invisibolt tubular cranks w/ 25-9 micro gearing w/ Aluminum SE sprocket.
* Odyssey Twisted Plastic Composite Pedals.
* Alex DM 24 double wall rims.
* 9t Shadow conspiracy raptor V2 sds system rear hub w/ 4-sealed bearings & female axle, front hub w/ 2-sealed bearings & female axle.
* Maxxis DTH 2.2" folding tires ,provide more traction and forgiveness on harsh landings.
* 10.15 kg !!!!!
SPECIFICATIONS
COLOR
Super polished chrome. 100% Cr-Mo, Double-Butted Main Frame, Integrated Seat Clamp, shadow Integrated Head Tube, Externally Machined Mid-BB, Removable Cable Guides & Brake Mounts
FORK
Full Cr-Mo, heat treated Tapered Legs, 3/8" Dropouts w/ 32mm Offset
CRANKSET
3-pc heat treated Cr-Mo, 175mm, Closed-End Reinforced Invisibolt Cranks, Sealed Bearing Mid Bottom Bracket, 25T Aluminum SE Sprocket
PEDALS
CHAIN
KMC Z410A
WHEELSET
SE Alloy 36H 3/8" Sealed Female Front & 14mm shadow conspiracy raptor V2 Rear Hub. Alex DM24 Double-wall Rims.
TIRES
Maxxis DTH folding tire front + rear
20" x 2.20
BRAKESET
Savage level : NO BRAKES !!!!
HEADSET
Tange Sealed 1-1/8" Integrated Headset
HANDLEBAR
Cr-Mo Powerwing Bar, 28.5" x 9"
STEM
SE Top-Load Alloy, Lightweight External Cutouts, Hidden Top Cap, 50mm Reach
GRIPS
SE DSP Grips w/ Rubber SE End Plugs
SEAT
SE Pivotal Seat w/ Padding (sickkk)
SEATPOST
Pivotal Lightweight Nylon & Fiberglass, 25.4mm
WEIGHT
10.15 kg!!!
GEOMETRY
TOP TUBE, ACTUAL
21"
 SEAT TUBE, CENTER TO TOP
9.5"
SEAT TUBE ANGLE
71°
 HEAD TUBE ANGLE
75°
 CHAINSTAY LENGTH
13.7"
 BOTTOM BRACKET HEIGHT
11.5"
 STANDOVER
22.7"
 STEM
50mm
 HANDLEBAR WIDTH
28.5"
 CRANK
175mm
 WHEEL SIZE
20"
SEAT POST DIAMETER
25.4mm
(Notice : i will buy the shadow 4PC 9.5" BLACK Bars as soon as next week! )
4/16/2017 10:48 AM
Looks good dude
4/17/2017 8:40 AM
Coopers25 wrote:
Looks good dude
thanks man smile
