Pictures are slightly off from reality, in that my bars are a small amount forward, seat slightly lower, etc. Anyways I've got another bike (built around a Kink Transition) but this is my main ride, I want to go LHD but short of that it's getting close to where I want it. Am about to order a new chain this week too, am stuck choosing between oil slick kmc 510, oil slick warlock half-link, odyssey hollow pin keychain, and the shadow half/half black/copper half-link; any thoughts/reco's on chains would be appreciated, in fact any thoughts, comments or suggestions on my bike would be greatly appreciated!
[Oh and the peg setup is now metal on the right side, and plastics on the left because I suck at grinding on my left, figured they'd help me]
Frame: United SU2 21” (pretty damn perfect frame IMO!)
Fork: United
Bars: Shadow Vultus 9.5”, cut to 26.5”
Stem: Eastern
Grips: Subrosa's in black w/ gold-flecks/sparkles and flanges
Barends: Subrosa nylon
Headset: United
Clamp: Integrated
Seat/Post: Shadow 1-piece
Pedals: Eclat Slash
Cranks: Kink (rawed and clear-coated) 175mm
Sprocket: Mankind 28t
Chain: KMC 510
Front Tire: DUO Stunner 2.20”, @105psi
Front Wheel: Cinema 777, United hub, pc hub guard
Rear Tire: Tioga PowerBlock 1.75”, @65-70psi
Rear Wheel: Kink complete wheel w/ 9t driver and Primo guard
Pegs: 4” all around, with plastic up front and metal in the rear.
Guards: Primo in rear, DIY in front
Modifications: Bars cut to 26.5, steerer tube cut flush to stem. Seat's fabric removed and sprayed with glittered-black Rustoleum. Cranks were grinded back to raw steel and clear-coated. Bike was 24lbs from the factory but has been brought to 23.2lbs (with the pegs!)
Notes: Everything is kept as tight and perfectly-tuned as possible- from chain tension and drivetrain alignment, bb and headset, everything's tight and with the tires pretty tight (100psi front / 70 rear) it's like a basketball when you bang its tires! Also after getting the 28t sprocket and putting the racing tire on the rear, I can get this thing going fast real quick, and it coasts for days like I can actually kind of do comfortable mid-range commuting on this build!
[ ^ those grips' wavy pattern is kinda weird but have been digging them!]
