Amity Crank.
12/23/2010 5:58 AM
Will the Amity Zenta Crank, fit my KHE, ive orderd it but now ive thought about the bearings:/
my KHE frame has bushes instead of bearings O_o
sorry if this is a nooby question:}
thanks.
Ride till i die.
12/23/2010 1:45 PM
It depends on your spindle size. From the top of my head, I think that the Amity cranks are 19mm, so as long as your bottom bracket has a 19mm bottom bracket, then it should fit. You'll have to try it out, and then come back here if it is too small/big.
Hope this helps wink
PSN - TheNunPoacher
