14mm pleg question
12/9/2012 8:49 PM
Is it possible to use peg adaptors in a pleg insert or will I need a new insert?
New refs: dgoulet1995, Mike - E
Resolving issues one by one
12/10/2012 12:52 AM
I'm sure it's possible, but I would just order the insert. If your dead set against spending money, make sure the adapter isn't wider than the insert hole, or the pleg won't be fully supported by the axle nut/bolt.
12/10/2012 12:56 AM
Yes it wouldn't change anything because the steel insert will make it work as a normal peg so you can just put in the adaptor and it's gonna be fine
12/10/2012 5:14 AM
Alright. Its gonna be a front left... and I grind right normally so I think it'll be fine
