Does anybody know an actual number value? If not, how tight do you put yours? Im trying to find a happy medium between the axle moving in the rear dropouts and fubaring a rear hub. Thanks
I just put my ratchet on to the socket and just torque it down that way. I don't really have any issue with my wheel shifting unless I catch it on a rail up right or something
Youll rip the threads out of the nut before you overtighten it, I run mine tight as I can pretty much, female on the otherhand is supposedly not supposed to be tightened as much but tight enough so the wheel doesnt move.
Thanks. Its a male axle so i will tighten em down some more to prevent any axle movement in the dropouts. Thanks
Anybody put grease on the male threads before tightening the nuts? Why would you? I never dod that on any motorcycle and never had any issues. Thanks
Anbody actually grease the axle threads before tightening the nuts. Thanks
Yes I grease all if my threads on my bike and they all move freely. you can tighten greased bolts tighter than dry bolts
95horsepower wrote:I knew it is recommended but didn't reallt think anyone took the time to do it.Thanks man
Just put a teeny bit.
