Hello Vital umm I can do a perfect 180, but the problem is that I do it by lifting both tires at the same time which is not a proper 180
I really want to learn proper 180s and Ive been trying em for 2-3 weeks and everytime I try to do one I lose balance or smth and fall over the back. I carve (not too much) so thats not the problem. I've tried without carving - same result
I got a new 20.75 frame 3 weeks ago. Could that be a problem? Last summer I was able to do 180s properly with a bunny hop by lifting first front tire and then the back tire (on a bank, but its still a 180) and I even did them with a good height (I had a 20.5 back then) + my bars a about 90 degrees to the ground, do you thing pushing them back a bit might help?
Now I cant do a single normal 180 Because I always fall over the back or just do it super lame and dont actually do it (for example I lift the back tire about 2-3 cm from the ground and underspin or smth)
I dont know what is the problem can someone help me pleeease because it is reeeeeeally frustrating
if someone has had a similar experience please share what helped you.
doing em out of a flyout might be good, but I want to learn them flat first
thanks
YO
