2016 Kink Liberty Sexton Bike
7/6/2015 1:39 PM
Is this a good bike
7/6/2015 5:49 PM
Yes, tires are fat 2.4 good 4 street
7/6/2015 10:49 PM
I have the 2015 version. I bent the forks, snapped the cranks, the stem slipped, and the axle stripped on the front hub. I still have the frame and the back wheel they are holding up great. You might not have those problems depending on how much abuse you put into it. Also I'm guessing its better than last years model.
7/7/2015 12:38 AM
Kink Liberty is the best bmx bicycle on the planet according to sunny.jomofo lolol.
It's pretty dialed for a beginner bike... Full chromoly frame, fork, bars & cranks, all sealed bearings, double wall rims...
Do you need LHD btw? Cause that particular model is LHD. If you grind on the right or plan to grind on the right, then it's fine, but if you grind or plan to grind on the left, you might wanna get the regular Liberty instead.
