25-9 to 28-9 big difference?
5/13/2019 1:49 PM
Is there a big difference pedaling wise going from 25-9 to 28-9 gear ratio? 25-9 seems to easy for me and I'm having a hard time finding a 27 tooth sprocket for a decent price. Any opinions welcome
5/13/2019 2:01 PM
28-9 is amazing, i live in a mountain area with big hills and im still able to pedal. its a solid medium. highly recommend
5/13/2019 2:06 PM
Lots of people seem to really like the 28t, more power per pedal and still not super difficult to climb hills.
Scooter kid trying to ride a bike. Instagram: @bmxereyn // YouTube: RH MEDIA
5/13/2019 5:14 PM
28 9 is good , I like 30 9 more but 28s a good starting point to see if it will work for you better
5/13/2019 5:29 PM
I went from a 25 to a 28 after my sprocket broke and I didn’t notice too much of a difference
5/13/2019 6:58 PM
Edited Date/Time: 5/13/2019 6:59 PM
Went from 25/9 to a 28/9 to a much nicer feel with more pedal response
5/13/2019 7:12 PM
I didn't notice much difference going from a 25 to a 28 but now, anytime I try somebody's bike with a 25, I feel like I'm spinning out on the first crank. I frequently spin out on my 28, cycling from spot to spot but I can't fit a 30t with a half-decent chainline so, I guess I'm stuck with a 28.
5/13/2019 7:25 PM
I used to ride 30-9 and it was an amazing gearing. Rode that way for like 2 years and never blew out a single bearing. I reckon 28-9 will be a perfect middle ground if you're on the fence. 25-9 is wack honestly
5/13/2019 7:41 PM
Is there a way to check if a 30 tooth sprocket will fit the frame before buying it?
5/13/2019 7:46 PM
I'd say to step up to a 28 first. It's a good middle ground between acceleration and top speed and most frames these days aren't built to accomodate anything larger than a 28(some frames won't even take anything larger than a 25(Cult Butter, IIRC)).
5/14/2019 12:48 AM
You’ll feel the difference for one ride, then you’ll wish you went to 28t sooner. 25 9 feels like you don’t go anywhere
5/14/2019 3:15 AM
28 is much better 25 is just for childs with small muscles.
Just take note that it will change your backend lenght a little bit because, 25 and 28 fall on different lenghts, 25 is 13.0" / 13.25" / 13.5"... and 28 is 13.1"/13.4 / 13.65"...
The 27t fall on the same lenghts as 25t, I'm running one atm for this reason only.
5/14/2019 7:32 AM
I ride 28-9 but will go back to 25-9 when I go down to 165 crank arms. 28-9 with 175s feels like 25-9 with 165s to me due to the lesser leverage and smaller circle i pedal.
5/14/2019 8:19 AM
I have a 28/9, get one from Steve. The Grey sprockets are rad!
5/14/2019 1:28 PM
It doesn’t make that much difference really. The smaller turning circle of the cranks will make 25t feel even more like you don’t go anywhere. I had 165mm cranks and a 28t and the torque felt the same
5/14/2019 11:32 PM
It will feel very different. Something you can get used to but depending on where you live and how many hills you have around, it could definitely be a beneficial change.
I personally do not like the feel but tons of people I know like them.
5/15/2019 8:41 AM
I've been riding 28-10 for over 10yrs. My new cranks seem slightly wider than my old ones, so I think I can run a 30t now with a good, but not great chain line.
Steve, do you still think your going to do a 30t?
5/15/2019 10:45 AM
Maybe, not enough interest to get them from previous supplier. But I might do a pre order type thing and get them made by the guy doing the stems
5/15/2019 11:44 AM
OT: When are stems going to happen?
5/15/2019 11:47 AM
Waiting to hear back from my guy, but I’m skint. If my guy gets back to me and is keen to get the ball rolling I’ll find the cash from somewhere. They’ll be super limited to only 25. So it could be a few weeks, could be a few months
5/15/2019 12:56 PM
What geo stem did you decide on?
5/15/2019 2:05 PM
I've been running 25-9 for years and I do agree it feels like I get nowhere, I have a 27T that I'm wanting to throw on with my 9 so will be interesting. Just have to figure out a method to keep my CS at the same length might need to deepen the slots a little, well see.
5/15/2019 2:38 PM
They’ll be about half a link difference in chain length, but you’ll barely notice the torque after a few cranks. When you’re already coasting and add a crank is where you’ll feel a massive improvement
5/15/2019 2:40 PM
50mm reach, 10mm rise while in the correct position, 22mmish when in topload mode. It’s basically an eclat burns stem but will look nicer
5/15/2019 3:32 PM
You can always look at the frame specs or call them
5/16/2019 5:49 AM
Nah, I've tried both. Smaller circles mean feet move less for more forward movement. In Geared bike circles its called "gain ratio" (not trying to get into it). 165 with 28 feels rough to me, that said, if i rode a cassette and the front of my knees agreed with it, i would run that to make for nice higher speed fakies.
5/16/2019 8:50 AM
Edited Date/Time: 5/16/2019 8:51 AM
I’ve tried both too. And it felt practically the same. Slightly harder on the old knees riding up hill, but better on my old hips. And better when doing tricks. But not a hugely different feeling, literally the kind of thing you’d be used to after half an hour.
Edit: and that was going from 175mm to 165mm, with 28 9. Half an hour and it felt no different apart from being a bit nicer for tricks.
5/16/2019 9:43 AM
I really felt it in the knees and had to swap back. 26-27 might be the ticket for me but i.m not going to get a guard sprocket in those sizes easily.
I compromised for now with 170s 28-9 and its ok, but i know my next frame will be shorter so 165s will go back on.
5/16/2019 10:26 AM
If its cassette. It'll also make landing fakie and keeping momentum easier as it'll have more leverage on the front foot.
5/17/2019 7:34 AM
When can we place orders?
