3 taps help!!
5/18/2014 11:04 AM
Ok so I have 180's down every time but whenever I try to 3 tap my front tire drifts down to flat before I can finish the the rest of the rotation.. Any tips for 3 taps.. Thanks
Bicycle motor-cross Motor bicycle-cross Bicycle cross-motor Motor cross-bicycle!
5/18/2014 11:56 AM
I did them alot when I had my cassette hub.
Basically , just aim to 360 . Once you get past 180 your backend should be below your front tire . Then basically you straighten your legs and just pivot on the tire. Just watch how you do it . I did 180 - 180 taps really slowly , some people do 270 - 90 taps and once you get to that point you can basically huck it and land a 3 fairly easily.
5/18/2014 3:43 PM
Use the brake or pedal pressure, and carefully lean back just a little.
