48 spline replacement spindle?
10/22/2016 10:18 AM
I have a pair of 48 spline crank arms, and I need a spindle/bolts/whatever else and I found everything I need right here http://m.ebay.com/itm/222065122039?_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20161006002618&meid=06e9e46ab5814cada2d66ad550037fdb&pid=100694&rk=1&rkt=39&sd=301881798152&_trksid=p2385738.c100694.m4649&_mwBanner=1
Is there any sort of compatibility I should know about? (My cranks are 19mm and so is the spindle in question)
10/22/2016 10:21 AM
10/22/2016 11:25 AM
The stuff you linked looks okay to me but I'd wait on another opinion since I pretty much only deal in pinch bolt cranks like my Powerbites. I'm just saying from my knowledge that you'll probably be fine.
10/22/2016 12:44 PM
Do you have the old axle to measure the length? Chances are you'd be able to play around with spacers to get it right, but some axles are different lengths
10/22/2016 2:37 PM
Do you have the old axle to measure the length? Chances are you'd be able to play around with spacers to get it right, but ...more
My friend has it, he's using it with his cranks. I'll have him measure it
10/22/2016 7:23 PM
1664 makes some sweet titanium 19 mm 48 spline spindles
