48h rims with 36h hub?
7/7/2014 1:23 PM
I have some 48h alienation rims and a 36h hub. Would I be able to lace the hub to the rims? I heard if you skip every fourth hole it will work but I'm not sure if that's true. Has any heard of doing this or knows someone who has?
7/7/2014 4:32 PM
I did a heap of research on this a bit back. I emailed the top 30 results for "BMX wheel lacing" on google (top 30 mail orders/shops that lace wheels.)
Most replied, all said it IS possible, but will be significantly weaker than a regular 36h or even 28h wheel and will require multiple spoke lengths and a TON of patience and trial and error. It will also be incredibly hard to true and will most likely never be perfectly straight.
7/7/2014 5:04 PM
I went the other way, 48h hub and 36h rims without a single issue aside from spokes being a bit of a pain to set up. Mine was dialed in with no wobble or hop, but I spent a couple hours on it dialing it in.
7/7/2014 6:00 PM
theres a tutorial online for it. it's actually just as easy as building a regular wheel where the rim & hub have the same hole count. probably just takes longer to true
7/7/2014 9:30 PM
tomdon wrote:
theres a tutorial online for it. it's actually just as easy as building a regular wheel where the rim & hub have the same ...more
Do you have a link to the tutorial? I'll try to find it anyways
7/8/2014 10:35 AM
it can be done, not that it should be done. maybe you can sell/trade the hubs/rims to either have a regular 36 or 48 spoke setup.
Insta: @devicacy
7/8/2014 7:16 PM
