A Old part Question
4/8/2014 8:06 PM
So as some of you may know i have a G-Sport complete wheel coming which is a monkey laced to a ribcage.
What i want to know is am i able to put my marmoset axle in the monkey hub?
I have a feeling that they use the same dimentions and the marmoset has a lifetime warranty on the axle which the monkey did not.
any help with this will be much appreciated
4/8/2014 8:24 PM
It should, according to this
"The MARMOSET uses exactly the same axle and bolts as the Monkey hub"
4/8/2014 8:59 PM
Thanks man that really clears it up for me smile
4/8/2014 11:09 PM
Wait a minute, the monkey was interchangeable with the homer, both using 20mm axles and bigger bearings, the marmoset is a 17mm axle with smaller ( but still large ) bearings.
It was brought up on bikeguide recently and G said it wont work. ( in the case of putting marmo axle and bearings inside a monkey/homer shell)
4/8/2014 11:32 PM
Mychaylo wrote:
Wait a minute, the monkey was interchangeable with the homer, both using 20mm axles and bigger bearings, the marmoset is a ...more
Marm is 20mm axle, Antigram is 17mm axle though which might be what you're thinking of
4/9/2014 5:18 AM
I talked to 'G' about this. You need a custom axle to use 10mm bolt in a monkey
4/9/2014 5:28 AM
That was me asking
4/9/2014 2:33 PM
Yeah i read that too just before
but wasnt that for using the bearings with it as the marmoset has a smaller OD bearing race but has the same axle?
And the monkey does use 10mm bolts, It was the homer and vandal that used 14mm
4/11/2014 11:45 AM
but wasnt that for using the bearings with it as the marmoset has a smaller OD bearing race ...more
I had a Monkey, and they were 10 MM bolts.
