A little help in deciding?
6/26/2012 5:44 PM
Edited Date/Time: 6/26/2012 5:47 PM
Alright so heres the problem =) I have a chain that seems pretty loose as you can see (BELOW). Now im not sure if i should buy a new chain and a chain breaker to put it on or if i should just buy a chain breaker and try to make my current chain tighter. Also as you guys can see when my cranks reach a certain degree the chain gets tighter would this be the cause of my sprocket or of my chain? If it is my sprocket can i continue riding like this or should i change the chain and sprocket to? I dont like to change stuff unless its useless and it would be cheaper to just buy the chain breaker what do you guys suggest?
&feature=youtu.be
Srry something happened it didnt upload the video to Vital if you wouldnt mind clicking on the link =)
6/26/2012 5:46 PM
&feature=youtu.be
6/26/2012 8:27 PM
It's most likely your sprocket, if its bent it causes a tight spot and the rest goes back to normal or loose, it might break your chain, so get a new sprocket
2Hi throwaway
Anti-street?
NEWER VIDEO
TRV-950 Footy
6/27/2012 2:12 AM
this. i had a bent sprocket a while back, and unless you like to hear your chain slamming on your frame, get it sorteed, or itll drive you crazy
NEW Bike check
Raw Clips Edit
