I have an AHEADSET Headset and the topcap broke. I could buy another plastic topcap but I was thinking of going metal, so what metal topcaps fit threadless 1 1/8" AHEADSETS.
I think most caps are universal though I don't know if you can buy just the cap?
fitbikerider14 wrote:Is it the kind that screws into the fork or is it one like this
second one
If it has a Hole in the middle for a Brake Cable and is undone using a Wrench it will use an M10 Topcap (Tree makes one). If it has no Hole and an Allen Key Insert then it will most likely be an M6 Thread. And it's only the little bit on the top that's Plastic, it doesn't really need any strength.
BMX_Forever wrote:If it has a Hole in the middle for a Brake Cable and is undone using a Wrench it will use an M10 Topcap (Tree makes one). If ...more
its an m6
just buy a new headset they are not that expensive
MIDWEST MOTHER FUCKER
biggybuggy wrote:It is a top cap, not bad bearings. Not blowing 30 dollars on a headset
its worth it, cuz you would be upgrading
I dont want to uprage from a brand new part that I just got
any top cap that has a hole in it should work.
http://www.jensonusa.com/Search?q=top+cap&x=-921&y=-154
your bike shop should have one as well.
biggybuggy wrote:the plastic topcap broke, that is all
Check your lbs for a spare one and if they don't have it order one.
My Fit
jj0996 wrote:just buy a new headset they are not that expensive
BMX_Forever wrote:Well he never said there was anything wrong with the Headset, did he? And if he bought a new Headset it wouldn't even have the ...more
all headses come with races, caps and spacers
fitbikerider14 wrote:Check your lbs for a spare one and if they don't have it order one.
shop closed, too many kids got hit by cars on the highway riding to it. . I go to scheels or order stuff
