Aloy or Brass
3/2/2020 9:02 AM
Pros/Cons to Alloy nipples on Street wheelsets? Anyone ever run Ti Spokes? Worth it or more PITA than they are worth? Weakier? Etc...
3/2/2020 10:25 AM
Brass all day, every day. Alloy nips just seize, or corrode and snap.
3/2/2020 10:33 AM
Ti nipples are an option now. I've always personally ran alloy started out with brass Tbh I don't thing I'll ever use brass again never had 1 nipple break on me and I do ride all things and am quite heavy, but that's not to say they don't break just my personal experience with them.
3/2/2020 2:35 PM
i been riding gsport nipples with no probs. Theyre powder coated(i think?), that may help protect against corroding. Lube them up and they wont seize.
as for snapping, make sure your spokes arent too short and youll be fine.
3/2/2020 3:12 PM
They're anodized; not powdercoated. I built a wheelset for my brother with G-Sport nipples and they lasted about a year and a half. After that length of time, they were so corroded that they'd just crumble and pull straight through the rim.
3/2/2020 3:23 PM
Wait, you can get brass nipples?!
3/2/2020 6:22 PM
the only advantage to alloy nipples is they come in a multitude of different colors and are a clearly immensely heavy 2-3 ounces lighter per wheelset.
Brass are better in terms of strength and reliability. I had alloy nipples a long time again and they eventually seized onto the spoke and believe me, it is not fun trying to remove them, plus truing your wheel like that is next to impossible. It doesn't always happen, but it's something that can be easily avoided. If you do go that route, just make sure you use some kind of spoke prep lube
another con about alloys is if you don't have the exact size spoke wrench, they will round incredibly easy. Obviously if you're an experience wheelbuilder you should already know that, but not everyone does and it's just something to note. Or maybe you're in a pinch and used the wrong size, idk.
3/2/2020 6:55 PM
ouch.
well i painted them black when i got em and used enough lube. I live and ride in dry conditions, i think theyll last a lot longer than a year.
3/2/2020 7:29 PM
Alloy are fine if you are going to rebuild your wheels with new nips within two years anyway. But if you want them to last a long time go brass. I’ve had tons of people bring me wheels to true but i can’t because the nipples are old alloy and just crumble into pieces when i turn them. As for ti spokes, i would say if you have to money, don’t ride pegs, only ride super smooth transition or race then they are ok. But for the common rider they are a waste of money and really fragile.
IG @curtis_cantbmxwell
@kirolling
3/2/2020 7:49 PM
I can't even begin to tell you how many times I've had to replace a nipple or even cut a spoke & replace both due to it being seized on there, so I can only imagine how many you get with the much higher volume of wheels you probably get at Powers
3/3/2020 4:22 AM
To be honest, I completely forgot about the seizing issue. Shows you how long it's been since I trued wheels with alloy nips. Or maybe I thought someone would have figured it out by now. Just curious, How's titanium to alloy or ti spokes/ti nips?
3/3/2020 4:27 AM
I’m 230lbs. I flair and my wheel with ti spokes and alloy nipples are perfect from the day they were built.
A properly built and tensioned wheel with ti spokes is super strong. I popped off a flair the other day and got weird. Upside I thought my wheel was destroyed. But it’s perfect.
I do keep a complete set of ti spokes for another wheelset in my bag whenever I do go ride just in case. But haven’t needed to open them ever
3/3/2020 4:38 AM
How long have you had the wheelset?
3/3/2020 5:40 AM
Highly recommend gsport nipples or brass, fuck alloy nipples! Lol
Testimony and apologies
instagram
old edit
3/3/2020 7:21 AM
BMXism wrote:
ouch.
Same
It amazes me how many ppl dont lube every bmx thread
Living in dry conditions def’ly has it’s benefits...til allergies kick in
Come, as you are. As you were. As “they” want you to be....
3/3/2020 11:51 AM
Edited Date/Time: 3/3/2020 11:52 AM
Gsport nips are alloy.
3/3/2020 3:53 PM
Its a pretty painful procedure but it is possible.
3/11/2020 10:58 AM
if you have patience and practice good calm bike maintainence, and care about minor weight reductions, then go with aluminum nipples. otherwise you will easily destroy your nipples
wallride a bus everyday
3/11/2020 11:19 AM
Titanium all day !
3/11/2020 1:25 PM
titanium when appropriate!
