An interesting project
4/14/2011 2:59 AM
Edited Date/Time: 4/14/2011 3:00 AM
so i've got a G-Sport Homer hub, 48 hole, and after examining it for a little bit the only difference between it and a marmoset is the freewheel threading and a little bit of excess aluminum coming off of the hubshell to the freewheel threading, other then that it looks like a marmoset. except 14mm bolts...
anyways... do YOU guys think it can possibly be "modified" to be a 14mm marmoset?
Homer link: http://store.odysseybmx.com/gsporthomerhubrearrhd.aspx
Marmoset link: http://www.gsportbmx.com/products/hubs/marmoset/
4/14/2011 3:52 AM
i reckon it could be done but it would take some work... and youd have to use 48h on a front wheel which is extremely unneccesary
Mothaducker.
http://www.youtube.com/user/CreativeUpload?feature=mhee
Go to my channel, sub, and click a couple of the ads, would be mightily appreciated!
4/14/2011 6:22 AM
Edited Date/Time: 4/14/2011 6:23 AM
No, because you would have to cut off the metal, clean it up, possibly move a bearing inside it in further, and chances are good something would go wrong. I wouldn't chance it. I would just save some cash man.
4/14/2011 7:42 AM
the marmoset is a front hub not a rear hub. your changing a rear hub to a front hub?
A bike is not a bike if it doesn't have air in the tires.
BSD Front Street Hub Review
Primo Mix Review
Why You WEAR a mouthguard!
Refs.
\BMX-1995/
4/14/2011 8:59 AM
Yea, sounds like he wants to cut off the threading used for a freewheel and turn it into a front hub.
The flanges are bigger on the Homer, same with the Monkey. Probably has something to do with the fact that he can get a 48h Homer for real cheap off Odyssey's site.
4/14/2011 4:15 PM
Biggest problem is that rear hubs are 10mm wider than front ones, so you would need to modify or make a new axle and collars too...
4/14/2011 4:19 PM
George French?!?
Swoop it motherfuckas
4/14/2011 4:56 PM
Austin_Read wrote:
George French?!?
You know it!
