Anybody have tips for 360s?
1/9/2014 6:04 PM
I've landed a couple 360s but i mostly get 3 taps or 270s, any tips?
Instagram @retard_with_a_bike.
That about sums it up :/
1/9/2014 6:07 PM
Keep practicing, they aren't gonna come to you overnight. Look over your shoulder too, carve a bit when starting the 360 and keep your head turned. A LOT of people will turn their head, get to the 180 point and then turn their head back the other way. Key is making sure your head is turned the whole way. I assume you mean flat 360s, that's how they're done.
1/9/2014 6:08 PM
Turn your head more and spot something in front of you on the ground. I used a sewer gate on the street and when you go to look look all the way around for the sewer gate. It works wonders. Try it. Also, huck your legs up and push out at about 180 so you land perfectly 2 tires. If you wanna dip it, push the front end out and down and huck your legs harder pulling the bike to you. And when you do this, look under your armpit because you will surely get more height and you will need to do that to help level it out.
360s are my favorite trick. I know all about them and love doing them anywhere.
1/9/2014 6:10 PM
I can get sooo close to flat threes. My problem is that i will rotate but land sideways like in wallride position and then my foot comes off. What do i do?
IG @curtis_cantbmxwell
@kirolling
1/9/2014 6:12 PM
about to go try thanks for the tips hope it works. and yes flat 3s
1/9/2014 6:34 PM
You are looking too goofy. My bro does this all the time. You are probably looking more to the side and not keeping your weight over the bike. Use my tip where you look at something on the ground and try and keep your weight over the TT.
1/9/2014 6:55 PM
Any tips for good taps? I like tap tricks. Like 540 taps and later future trying 720 cabs. People I know are really going at it.. Landed a couple for them..
1/9/2014 6:59 PM
keep your front up and just pivot, and don't lift your back end up as much. once you get to the 360 tire tap mark, just like 180 out of that for 540 taps & for 720 taps, do the same thing but don't let your front drop. It's easier spinning faster because the momentum takes you, I've done a few 1080 tire taps and even a 1260 tap. once you figure out the 360 tire tap to 540, you can pretty much piece together the rest but it takes a good bit of effort
1/9/2014 8:37 PM
disappointed nobody has posted this yet
?feature=player_detailpage
Subscribe to me on Youtube.
1/9/2014 8:40 PM
Hahahaha that grandma rules
