This what happens when u run pegs(with Anti-spin Knob) on the Fit Dak frame,
I also bent the left side inwards from grinds!
Bike Check:
Wethepeople A2B Frame 20.85
Odyssey Directors
Odyssey headset
Fit DLR Real Tree Camo stem
Odyssey Space Bars
ODI LongNeck grips
Odyssey Twombolts 175mm
Fit BB
Fit DL sprocket 25t Real Tree Camo
Odyssey Twisted Pc's
Shadow chain
Odyssey Mr.Clampy II seat clamp
Federal pivotal slammed
Kink slim pivotal seat
rear wheel- Odyssey Hazard Lite/Odyssey V3 Cassette 9t(odyssey driver)36h
rear hub gaurd- BSD
rear tire- Odyssey Path Lyte 2.10 folding
front wheel- Odyssey 7KA/G-Sport Marmoset 36h
front tire- Fly Ligera 2.25 folding
front hub gaurd- Knight
pegs- Shadow lil ones
Mods- cut steer tube down
rear wheel is slammed at 13.25
Frame specs:
MODEL
A2B - ASHLEY CHARLES
Machining:
Full Magma heat-treated 4130 Sanko CrMo(post weld heat-treatment)
Tubing TT:
ø33mm double butted, DT: ø36mm offset butted, butted seat-tube
Toptube:
20.85"
Chainstay Length:
13.25” to 13.5” on wishbone rear triangle
Angles:
HT: 75°, ST: 71.5°
Bottom Bracket Height:
11.8”, new shape Mid size BB
Headtube:
Int. Headset, drilled for included gyro tabs
Dropouts:
Invest cast, hollow, 6mm, heat-treated, 4130 CrMo
Weight:
4.9lbs
Increased butting thickness at SS/CS junctions
Invest casted hollow SS bridge
Invest cast hollow 6mm dropouts
