BMX CRANK/bottom bracket noise
7/16/2018 4:46 PM
I checked my pedals and cranks and there is no play coming from the bottom brackets, but there is slight noise whenever I pedal mainly to the left hand side do you think that this is okay? Do my bearings need regreasing? Would it be fine , since I have been riding the bmx like this or maybe since I got it and I think that this is a normal noise and there have been no problems. do you guys think it is fine and does not need a checkup or regreasing? I think it should be fine and absolutely is normal, is it normal? What’s your opinion guys?
Please help thanks
7/16/2018 5:43 PM
If it's creaking. It could be metal on metal without sufficient lubrication. It'll be fine but if it annoys you, try removing the crank arms and greasing the splines.
7/16/2018 7:02 PM
are they 8 spline cranks? and is the noise when you put pressure down on the cranks? if so, grease the spindle splines then put it back together, that's probably the culprit
