BMX back wheel Cassette hub problem :(
1/20/2014 6:01 AM
My Cassete hub has stopped making any noise after i greased the teeth, should i be concerned about this? Or will the noise come back later. unsure ermm
instagram: @TandosAwesome | Bike Check: N/A | Xbox gamertag: OS2 Tando
1/20/2014 6:14 AM
what did you grease? the driver teeth, or the driver pawls? (which are inside the hub), if you greased the driver teeth, then it's not normal.
1/20/2014 6:20 AM
ivancuestabmx wrote:
what did you grease? the driver teeth, or the driver pawls? (which are inside the hub), if you greased the driver teeth, then ...more
sad i greased the driver teeth unsure so does this mean i've kinda fucked up?
1/20/2014 6:27 AM
_TandoM_ wrote: sad i greased the driver teeth unsure so does this mean i've kinda fucked up?
that's really weird it's the first time i hear that, did your hub make any noise before greasing the teeth? i don't really see how would you be able to fuck it up just by greasing the teeth
1/20/2014 6:33 AM
that's really weird it's the first time i hear that, did your hub make any noise before greasing the teeth? i don't really see ...more
yeah, but then after i greased the teeth and then after riding for at least 30 mins it went completely silent.
1/20/2014 6:36 AM
oh then the problem has nothing to do with greasing your teeth i think.
you have to take apart the driver and check the pawls and the inside of the hub. take pictures of it and post them
1/20/2014 6:39 AM
you have to take apart the driver and check the pawls ...more
is it simple to take the driver apart? wassat ermm dizzy
1/20/2014 6:41 AM
yes, but probably your rear hub is unsealed and removing the driver might make them fall, anyways you can always put them back. what was your bike model?
to remove the driver, just loose the driver lock nut and take off the driver
1/20/2014 6:59 AM
yes, but probably your rear hub is unsealed and removing the driver might make them fall, anyways you can always put them ...more
i have a Mafia Clip 1 BMX and i'll look for a youtube tutorial or something tongue at least this doesn't stop me from riding my bike silly but thanks for the help though!! tongue
1/20/2014 8:28 AM
Grease quietens the hub, and as your bike has an unsealed driver the grease will of went in to the driver. It is better for your bike. I know the complete wheel Mafia sells comes with the Driver ungreased (Which is REALLY stupid) so it might be the same on your wheel. A quiet hub is not a broken hub.
1/20/2014 8:38 AM
^^^^ it should be fine
Murica bike check
1/20/2014 8:39 AM
Edited Date/Time: 1/20/2014 8:40 AM
Edit: double post
Murica bike check
1/20/2014 8:56 AM
If it aint broke, dont fix it. Aslong as it engages and doesn't skip, it should be fine. If youre that worried about it take it to your LBS. My advice for you is to never open up an unsealed hub.
1/20/2014 9:03 AM
BMX_Forever wrote:
Grease quietens the hub, and as your bike has an unsealed driver the grease will of went in to the driver. It is better for ...more
smile Thank you so much! i can stop worrying about my bike now :D... thanks again!
1/20/2014 9:04 AM
HardBMX_Tim wrote:
If it aint broke, dont fix it. Aslong as it engages and doesn't skip, it should be fine. If youre that worried about it take ...more
Thanks Tim, you've been massive help! :D... i'll just leave it since nothings really wrong, thanks again
1/20/2014 9:10 AM
No problem buddy. But for Christmas/your birthday ask for one of these -> http://www.danscomp.com/products-PARTS/401191/Mission_React_Cassette_Wheel.html . That unsealed hub will become a pain in the arse pretty fast. Thats probably the first thing youll want to replace on it.
1/20/2014 11:27 AM
Yeah, unsealed hubs are a pain in the ass man
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
