They both have polymer bushing drivers and both have 14 mm female axles but the BSD is newer and simpler. Wondering which will hold up best and which is fastest. Also has anyone had any problems with either?
Both virtually the same. Same bearings, axle diameter, bolts, etc,
Shadow has higher engagement and is less likely to skip due to more pawls.
Only advantage to the BSD is the lack of engagement which can help when it comes to fakies.
I would personally go BSD but they should both be great hubs. Try to keep it to one thread if it's on the same topic as one of your recent ones. Isn't this your third thread this week about hubs? Just a tip, it keeps the forum less cluttered
IG
@curtis_cantbmxwell
blaaaaaaaaa wrote:I would personally go BSD but they should both be great hubs. Try to keep it to one thread if it's on the same topic as one of ...more
Fuk da rulez
Get the BSD.
REFS-
Wich is fastest ? What a silly question , it's a hub not an engine it doesn't give you speed your legs do that
I had the BSD for a while it was definitely a good hub and I've always heard good things about the BTR so i'd think either one of them would be a good choice (spec wise it seems alittle better) just depends on which brand you like more i guess
Murica bike check
