Xxohioanxx wrote:
I'm between 6' and 6'-1" tall as well. I run a minimal dust cap, no spacers, a mid rise topload, and 8.5" bars. It's perfectly ...more
Xxohioanxx wrote:
I'm between 6' and 6'-1" tall as well. I run a minimal dust cap, no spacers, a mid rise topload, and 8.5" bars. It's perfectly fine for me. The taller your front end gets, the lower your hops get, generally speaking. But if you do want more rise, it'd be better to get a tall top load stem than taller bars. Taller bars add weight, are weaker and will slip more. Tall top load stems get your front end higher with none of these down sides. 8.75" is as tall as I would go for bars. Anything higher can be added using a taller stem or spacers.
Majority of all butted bars on the market and similar in weight, some bigger are even lighter. The differences are so minimal youre not going to notice a difference unless riding straight gauge bars like 11's or 10's and even so, its still not a problem. As for strength, weight, performance, reliability...no matter what size you get, I guarantee as long as buying a well known brand, you wont have any problems. Im 6'4, have rode 10 and 11 rise bars since coming out and never have I had my bars slip, crack, break, bend...etc. The weight causes no hindrance and they feel more solid then lighter butted bars. I highly recommend Tree bars bar as well.
OP, I see a lot of people with your height happy in the 9.5- 10 rise area. It is personally preference though, Im sure as you go higher, later in time youll probably go up a size as well. Goodluck on your search.
REFS-
