Bb size
4/4/2013 10:29 PM
Hi I need new bottom bracket bearings but I don't know what size I need for the bearings can someone help
4/4/2013 10:34 PM
what frame and cranks?
4/4/2013 10:34 PM
Edited Date/Time: 4/4/2013 10:37 PM
19mm BB fits 19mm spindles
22mm Bb fits 22mm Spindles
I believe one is called American Bb Spanish Bb Mid Bb and Euro Bb
Most standard bikes have either a Spanish Bb which I believe comes in 22mm or a Mid Bb 19mm? might be wrong though
4/4/2013 10:37 PM
I have a free agent BMX bike
4/4/2013 10:38 PM
Edited Date/Time: 4/4/2013 10:39 PM
Gonna need more specific specs....
4/4/2013 10:38 PM
they've used mid, american, and euro. gota be more specific. model and year
4/4/2013 10:43 PM
I think you'll need 15mm Indian bearings.
No, seriously. Gotta get the year and model exactly.
4/4/2013 10:44 PM
It's a trail duster
4/4/2013 11:02 PM
I looked the bike up and it's a one piece crank.. so it's an American, and assuming it's all stock.. this is what you need.
http://www.danscomp.com/products-PARTS/455018/Odyssey_Dynatron_1-pc_BB.html
snap a pic of the cranks just so we can make sure
4/4/2013 11:04 PM
Mine is not one piece
4/4/2013 11:06 PM
4/4/2013 11:07 PM
This is the bike
4/4/2013 11:18 PM
Can you post a more clear pic of the non drive side looks unsealed american bb tho
BikeCheck Refs:
BEASTASSDICKwink,Flocka Myers, ecuadevil,White Knight, bmxing12 ,obiwan chromoly,ScramHype, Hatebreeder,SnM An1mal,isnowyaznV2
4/4/2013 11:27 PM
Edited Date/Time: 4/4/2013 11:27 PM
Could be unsealed mid. I've seen them on Diamondbacks. Only Poverty makes unsealed mid though. http://www.danscomp.com/products/455097/Poverty_Carmi_BB_(Unsealed).html
4/5/2013 6:55 AM
It's american.
Yours also looks unsealed. but You SHOULD be able to fit a sealed bearing BB in there.
Why do you need/want a new BB?
4/5/2013 3:25 PM
Looks like unsealed American BB to me.
4/5/2013 9:36 PM
if its unsealead american then to put an american sealed you would need to get a new spindle http://www.danscomp.com/products-PARTS/455080/Mission_Chromoly_Spindle.html assuming its 8 spline.. technically the spindle on unsealed cranks are 15/16" but a 19 mm should fit... then you need sealed bb... http://www.danscomp.com/products-PARTS/456061/Mechanik_BB_Kit.html this in the american size is what you would need... then you would be set... this is what i did with my unsealed bb and poverty cranks... otherwise you would need the bb sunday said.. the oddyssey http://www.danscomp.com/products-PARTS/455018/Odyssey_Dynatron_1-pc_BB.html hope that helped
4/6/2013 12:04 PM
pnj wrote:
It's american.
Why do you need/want a ...more
They are broke
4/6/2013 1:18 PM
pnj wrote:
It's american.
ronnie.gant.7 wrote:
They are broke
Do they not spin anymore at all or do they have some tight spots.
4/6/2013 2:56 PM
When you pedal backwards its a crunchy sound it makes
4/6/2013 2:59 PM
Well does it affect your riding, because if it's only some sound you don't need to risk replacing some loose balls.
4/6/2013 3:03 PM
No but I don't like that sound is it maybe because my bottom bracket is loose
4/6/2013 3:05 PM
It can be anything, some times chains make a rattling sound when riding backwards.
Just lube up everything and see if there's still the same sound.
If the cranks spin fine I don't see the point in changing the BB.
Post a video if you can, that would help.
4/10/2013 10:42 AM
Hi bike guru here a lot of times when you pedal backwards it indicates it is a freewheel issue not a bb if you have a freewheel and usually on a loose bb bikes it has a freewheel on the rear hub so get some wd40 and turn the bike on its side a spray the freewheel at the same time pedal the bike while spaying it and I should clean out and dirt in the freewheel and quiet it down. If it quiets it down that was your problem if not the bb needs to be cleaned or checked to see if it has uneven wear on the bb cups from the bearings rotating unevenly or one of the cups are cracked on the bearing race or just dirty from grime and such. Bike guru.
6/6/2013 10:31 PM
Thanks i fixed that problem but now a have a question .
I recently got a fit frame off someguy and it once had gyro brakes on it and they
took it off now it has brake mounts on the frame and there metal is there a way they can be removed
6/6/2013 11:14 PM
Get some synthetic grease and get those puppys greased.
FBM Pizza Beer Roast Machine
