Best 3/8" to 14mm Adapters?
10/3/2013 2:15 PM
Which 3/8" to 14mm adapters are best? Im running some shitty Mongoose adapter on one side and a peg on the other tightened down really hard atm and it doesnt look safe haha. I will be running a peg on one side. Which is the most reliable?
I found hat washer things, ones that go in the forks, ones that thread on or the bolt ones but idk which one would be best or most commonly used.
Instagram
10/3/2013 6:32 PM
They all do the same thing.. just get danscomp peg adapters I guess? They're cheap and simple.
10/3/2013 7:41 PM
i have ones that bolt over your 3/8 axle like sleeves, and then you use a 14mm nut
MIDWEST MOTHER FUCKER
10/4/2013 12:10 AM
If you have a lathe, make some with it. That's what I did.
