Best Casette wheel???
8/28/2016 3:24 PM
My friend dented his stock single wall back rim, and he decided he'd rather get a new wheel then re lace the hub to a new rim. It also has to be a left hand drive, as he has left hand drive cranks. I'm also curious as to what the best right side drive wheel would be (unless a good wheel can be ordered in both LHD and RHD) as I don't think my stock one will hold up for much longer.
8/28/2016 4:07 PM
It depends what you're using it for and what your budget is. I've got no complaints about my profile mini, everything about it is just right. But I have the female axle with 3/8ths bolts which I wouldn't trust with heavy peg use.
There are a couple of switchable hubs (or there were, I haven't looked into myself) like the wethepeople supreme switch hub, which would do the job for the average rider
8/28/2016 4:13 PM
It depends what you're using it for and what your budget is. I've got no complaints about my profile mini, everything about it ...more
When I buy a new wheel, I'll spend up to $200, same with my friend. We both grind, so male axles are preferable.
8/29/2016 12:27 PM
I'd go with the Primo Remix v2. It's based around Primos proven driver set up (see Primo Mix and Cult Match) but with a true 14mm female axle, which is the absolute strongest axle choice. You could have it laced to a Sun Big Baller rim, after using a discount code it would come out pretty close to your $200 budget.
