Bmx chain won’t fit on both gears but it’s the same chain I’ve been using for years
1/23/2020 5:01 PM
I did not get a chain replacement and wanted to start using my bmx again but when I go to put the chain back on the gears it won’t fit I’ve used the bike before and it was perfect
1/23/2020 5:37 PM
Edited Date/Time: 1/23/2020 5:38 PM
Do you mean the chain is too long/too short?
Or do you mean the way the chain sits on the gears doesn’t run smoothly?
Or is the chain too narrrow/wide to fit the teeth?
In what way does it not work?
1/23/2020 5:58 PM
The chain is too narrow but it’s the chain that came with the bike so I’m not sure if I just have to go to my bike shop or if I can fix it at home
1/23/2020 6:25 PM
Sounds like you have a 3/32", instead of the 1/8" chain you should have, ie. it's not actually the same chain.
1/23/2020 9:03 PM
There's only one logical explanation here.....
Sorcery!
1/23/2020 9:47 PM
I agree with p1, there's a chance that your sprocket/driver has worm out to the point where the chain won't fit, but that's very, very unlikely.
1/25/2020 11:53 AM
Edited Date/Time: 1/25/2020 11:54 AM
There is no way a chain would fit width-wise one day and not the next, unless components were switched out or the chain/sprocket/driver was very badly damaged.
You got any pics of the situation?
1/25/2020 12:06 PM
I'm guessing you have a different pitch chain, you need to find your other chain.
1/26/2020 9:48 AM
Yeah, it really sounds like you have the wrong chain. Chains can stretch, but not narrow in over time.
2/5/2020 3:21 AM
I don't thinik you explaining this very well. no one understands whats going on. post pics
2/5/2020 12:33 PM
I had the same problem when I put a different back rim on my bike. I just had to switch chain's. Got lucky and had one laying around.. I don't know shit about all these numbers. Back in my era erything was interchangeable
J. Stjohn
2/5/2020 1:44 PM
Edited Date/Time: 2/5/2020 2:05 PM
What does your rim have to do with your chain?
Since changeable bike gears were invented, there's been a need for narrower chains to avoid having the chain clip on larger cogs: [link] This is why there are different sizes around these days. To complicate it further, some freewheels and (IIRC)drivers run 3/32". General rule is: if it's for a bmx, put a 1/2"x1/8" on as it'll work on both 1/8" cogs and 3/32" cogs.
2/5/2020 2:35 PM
A lot of people mistake the term "rim" for "wheel".
For Rizok
-Wheel is usually a term used to describe the entire assembly (Rim, spokes, nipples, Tire, tube, rim strip, hub shell, axle, driver, etc.)
-Rim is the hoop like object that the tire mounts to.
2/19/2020 11:51 AM
”same chain & years”?
Get a proper, new chain
Come, as you are. As you were. As “they” want you to be....
