7/1/2015 6:22 PM
Edited Date/Time: 7/1/2015 6:28 PM
Welcome to the forum.
Isn't your compression bolt and stem cap the same thing? I mean BMX forks, etc, work all on the same principle. The cap is just a big compression bolt... Post up a pic, man.
Why would you need a new head set anyway? Bike is 2015 new, you don't see the headset itself, spend money on something that makes more sense, like I dunno, new bars or tires or grips, or chain lube, or sth. If it's workin' it aint need replacin'. As simple as that. Even my headset has a broken spacer, runs fine, so no touching there.
That's just my personal opinion anyway (and they're worth nuthin), and forums are a place to express them, so judging my words won't be tolerated.
If the bolt is smaller than your cap, you've got a problem, cauz you would have no place to put that smaller diameter bolt... You see, the cap is the thing that preloads the bearings by pushing down on the stem, and that, in a way, holds the thing together.
Nay, order, try it out, and if it doesn't work, polish it real good, send it back, ask for a refund, and eat a marshmallow.
You're in the states anyway. You can order and have stuff in front of your door the next morning! For me it took a friggin 5 weeks to get here! You guys just take things for granted...Lucky donkey holes...
Tell you what. Ring up that online shop, and ask them the same question. voila! problem resolved.
Cheers.
