Bolt Drive vs Spline Drive
3/17/2014 2:40 PM
Is there actually much improvement from bolt drive to spline drive? What differences would you notice when riding?
3/17/2014 3:04 PM
Yes. It ensures your sprocket is completely straight, so there is no tight spot in your chain or anything. It feels much, much smoother. 30/10 with a spline/socket drive sprocket, a perfect chainline, and sealed pedals is pretty much the smoothest drivetrain you can get (Not including any bigger gearing).
3/17/2014 3:10 PM
Xxohioanxx wrote:
Yes. It ensures your sprocket is completely straight, so there is no tight spot in your chain or anything. It feels much, much ...more
This.
I just personally wouldn't run a 48 spline spline drive because I fear it would wear out the splines in the sprocket overtime like 48 spline crank arms can wear out. Not saying it will for sure, I don't even know if it would but it seems like it would to me anyway.
3/17/2014 3:19 PM
I run a macneil lambo spline drive on my practice bike, no problems in the year or so I've been running it, feels smooth as fook and somehow stronger than any bolt drive ive used in the past.
Only bad thing I've got to say about spline drive is that it was a fucking bitch to install it, took ages, no joke it took blood & sweat...it fucking sucked.
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
3/17/2014 5:17 PM
Yup the difference is it gets rid of tight spots (what ohian) said, I'd never run it just because i dont want it to kill the splines on my cranks
Murica bike check
3/17/2014 5:18 PM
handlebar-to-face wrote:
Yup the difference is it gets rid of tight spots (what ohian) said, I'd never run it just because i dont want it to kill the ...more
So... jumping off tall ledges and huge lateral stresses won't kill the splines... but pedaling will?
3/17/2014 5:45 PM
Nope
Murica bike check
3/17/2014 7:35 PM
sundaybmxRR wrote:
This.
I just personally wouldn't run a 48 spline spline drive because I fear it would wear out the splines in the sprocket ...more
i have actually worn one down on my fixed gear freestyle bike
"Of course theyre compatible theyre cranks"
3/17/2014 7:59 PM
but seriously though.. does it happen often that 48 spline cranks wear down and wobble a bit? =/ had i known this i would of spent the 10 extra dollars on the oddysey thunderbolts.
Deviant BMX store
3/17/2014 8:01 PM
DeviantBMX123 wrote:
but seriously though.. does it happen often that 48 spline cranks wear down and wobble a bit? =/ had i known this i would of ...more
i wouldnt worry about it honestly. i put 48 spline on my girls bike and ive pushed that bike pretty hard,
3/17/2014 9:14 PM
They wear down if you put them on/take them off improperly. Have you ever heard of the splines on a car wearing out?
FBM Pizza Beer Roast Machine
3/17/2014 9:18 PM
no?
Deviant BMX store
3/17/2014 9:19 PM
no?
exactly. things like driveshafts and steering columns are splined, and they don't just wear out from getting used..
3/17/2014 9:22 PM
But to be clear, they do wear. As we've discussed before, 95% of BMX riders have the IQ of a rock and can't even properly install 48 spline cranks, which is why I believe it is an inappropriate interface.
3/17/2014 9:24 PM
sooo. i can guarantee that i installed them wrong(didnt have the tool that was needed) but if it is fine and not wobbling is it still gonna cause troubles? (im not as worried as it may sound just intrigued )
Deviant BMX store
3/17/2014 9:27 PM
sooo. i can guarantee that i installed them wrong(didnt have the tool that was needed) but if it is fine and not wobbling is ...more
if you greased them and then put them on, you should be fine. If you didn't grease them, hope you can snap em and warranty...
3/17/2014 9:31 PM
haha theyre greased.. and they are stolen teams sooo i doubt ill be snapping them anytime soon.
Deviant BMX store
3/17/2014 9:32 PM
I've installed my 48 spline Animal cranks properly & kept them tight always, and they still wore out. Out of the 4 48 spline cranks I've had over the years, all but 1 of them developed this wobble & I could actually see the splines in the crank arm twisted. My Sputnic cranks never did that, but I didn't have them as long as I had the other ones though.
3/17/2014 10:01 PM
Edited Date/Time: 3/17/2014 10:04 PM
I had the best Salt 48-S cranks first time and babied them for almost 3 years until I got my Stolen Team 2.5's about half a year ago or more, which I now regret. The Salt cranks always stayed tight and everything and installing spline drive was amazing, lasted me also the 2 and a half years I ran my first spline drive. Can't wait to get back regular 48-spline cranks so I can run that thing again. And grease the sprocket splines well enough first time so that they break in and can slide on and off easily when adjusting or maintaining your drivetrain.
3/18/2014 7:30 AM
sundaybmxRR wrote:
This.
that
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
3/18/2014 7:57 AM
This isn't entirely true, because when I was into road/track bikes everything is bolted, and tight spots were determined by the roundness of the chainring/sprocket. Even a 48 spline sprocket could be machined so that it is oval, creating tight spots regardless of how straight it is. A well machined bolt drive sprocket should be no different than a well machined 48 spline
3/18/2014 9:45 AM
sundaybmxRR wrote:
This.
Mine is a year and a half + old without a single issue on a 48 spline crank.
It likely wouldn't any more than a crank arm would, unless it had room to wiggle in some way.
3/18/2014 9:58 AM
It's a bithc to get on, that is certain.
I run a Demolition Mugatu spline drive sprocket.
Bruh
3/18/2014 10:13 AM
FEDEXdoobie wrote:
This isn't entirely true, because when I was into road/track bikes everything is bolted, and tight spots were determined by ...more
In general with bmx though tight spots are caused by people tightening the bolt before they put the crank arm all the way on and it ends up cockeyed. Or they overtighten the bolt.
Deviant BMX store
3/18/2014 10:44 AM
anybody have experience with socket drive? now that tree is going to be making socket drive sprockets, im kinda intrigued.
selling refs: see profile
Instagram
3/18/2014 11:28 AM
I think he is referring to side to side wobble from the sprocket, causing similar effects to an out of round sprocket with a tight/loose spot.
3/18/2014 12:32 PM
dave lawrence wrote:
I think he is referring to side to side wobble from the sprocket, causing similar effects to an out of round sprocket with a ...more
Pretty much. The center bore will never be exactly 15/16", 22mm, or 19mm, and sometimes it's far enough off to allow you to bolt your sprocket on to the crank while the sprocket is not centered, creating the tight/loose spot. Wow, I'm really bad at explaining things but maybe that's clear.
@ticaleb: I'm running a Socket Drive Tree Lite right now. Socket drive probably isn't the only factor in this, but it feels a bit smoother than spline drive. Maybe it's just in my mind though. It's a lot easier to install, just grease it up, press it on, and go.
3/18/2014 12:43 PM
tree is legit
RIDE OR DIE
THE ROUTER
3/18/2014 12:44 PM
Edited Date/Time: 3/18/2014 12:44 PM
sorry for the double post.
RIDE OR DIE
THE ROUTER
3/18/2014 1:41 PM
T-rider wrote:
tree is legit
true story
Instagram
