Brake setups
3/4/2018 11:07 AM
I am debating on how to set up my gyro, should I just run dual cables all the way or should I run dual from leaver and gyro cable from the gyro or some thing else? What difference does this even make?
3/4/2018 11:17 AM
Dual cable is better and has more adjustability
Hmmm
3/4/2018 11:30 AM
Atleast do dual lower
3/4/2018 11:43 AM
Edited Date/Time: 3/4/2018 3:04 PM
What difference does it make? That’s what The Smiths said.
Dual all the way with London mod and M2 lever if you can. I use a regular upper cable cause I can’t get dual to work with a Dirty Harry lever.
3/4/2018 12:26 PM
Dual all the way with London mod and M2 lever if you can. I use a ...more
Have you tried the colony upper cable?
3/4/2018 1:22 PM
All of those dual uppers are the same, just different brands. It works with the lever but is in the way when trying to put the lever at the angle I want it 'cause it takes up space at the back. Hard to explain. But a regular upper works for me.
3/4/2018 2:15 PM
If you have a lever that accepts it, I think dual works better.
But single cable into dual cables still work really well if setup properly.
