Broke Primo Balance Freecoaster on 3rd day
5/10/2020 6:30 AM
You heard it here first folks. Photo
5/10/2020 9:05 AM
The internal mechanism broke?
5/10/2020 9:30 AM
Is this one of the hubs with 14mm bolts in a 15mm axle? Such a bad idea.. But what’s broken? Am I missing something?
5/11/2020 5:05 AM
Idk what's broke look at it. Can't you see the chipping of the outside. And when I ride it I feel a clunk every six feet.
5/11/2020 5:06 AM
5/11/2020 5:14 AM
The cone nut looks like it was made in a much softer material than what it should have been, which is why it looks ugly and damaged.
But the clunk you hear is normal for a new coaster, just ride it a session or two and it will go away forever.
5/11/2020 8:41 AM
Toss it in the garbage , buy a new one
5/11/2020 9:26 AM
Hmu if you want to sell the wheel lol
Testimony and apologies
instagram
old edit
5/20/2020 1:15 AM
Damn straight I threw that shit right out of my window
7/23/2020 8:01 PM
go suck a fat one faggot
7/24/2020 7:33 AM
warranty it
Husky Nation Member
7/30/2020 1:32 AM
If you don't install the hub guard, you with wear into the cone nut.. it's friggin' aluminum.. the pop is your clutch sticking because the grease needs a bit of time to work its way around in the hub.. re-install it and go ride.
Also, anybody who chucks a new bike part out their window before figuring out the situation is a wingnut and I hope a dog urinated on your wheel while it was outside.
9/11/2020 7:11 AM
i bloke the clutch,what clutch should fix with internals?
9/11/2020 8:09 AM
get fiend cab v2 instead, its same internals but its 14mm male axle
9/11/2020 8:38 AM
cult crew fc should match?
9/11/2020 9:56 AM
the clutch in it looks similar but the axle is way different
9/15/2020 12:57 PM
Reach out to Primo / Tip Plus and see if they can help.
9/15/2020 1:40 PM
Laz wrote:
If you don't install the hub guard, you with wear into the cone nut.. it's friggin' aluminum.. the pop is your clutch sticking ...more
"Wingnut" as an insult. 5 points for you, sir.
I shall be using that one.
9/17/2020 9:34 AM
The inner face of your dropout might be gouged or damaged by the looks of the mark. I'd take a look at it. You'll end up messing up every next hub you put on because of it.
